I'm running an E4300 at 3GHz (9x 333FSB) at 1.2875V cooled by a Thermalright 120 Extreme. I have the voltage set to 1.2875V (below rated maximum of 1.325V - have found it to be stable at the lower voltage so I left it), but I'm concerned that I'm still receiving temperatures higher than what I'd expect for that speed / voltage / CPU. Following are measurements taken at two different times (case temp being the CPU temp reading given by the mainboard, and TAT being the internal temperature given by Intel Thermal Analysis Tool):
Ambient: approx 22C to 23C
Idle: 24C (case) / 39C (TAT)
Super Pi + Prime95: 43C (case) / 56C (TAT)
100% Load via TAT: 48C (case) / 61C (TAT)
Ambient: approx 26C to 27C (best guess - was after room had heated up some w/ a couple people and PC's in it)
Idle: 25C (case) / 41C (TAT) [measurement may be invalid due to SpeedStep]
Super Pi + Prime95: 47C to 48C (case) / 60C to 61C (TAT)
100% Load via TAT: 52C (case) / 66C (TAT)
Given that I'm not over-voltage and I know people run E4300's over 3GHz, I'm a little concerned by the temperatures - I would have expected lower w/ the Thermalright 120 Extreme (beast of a heat sink). I've tried re-installing the heatsink with varying amounts of thermal compound, to see if I was using too much or two little, but temperatures don't change hardly at all whether I use a grain of rice, a BB, or twice that. Currently I'm using some Antec Silver Reference thermal compound that I've had around for a few years, but has worked ok on other machines that are running stock.
Might I fare better using AS5 compound? Should I see about lapping the heatsink / heatspreader? Should I be applying a different amount of compound or applying it differently (I've always used the edge of a sheet of paper to spread it smoothly over the whole surface of the heatspreader, rather than leaving a blob in the middle and trusting to pressure to spread it out)?
Any thoughts much appreciated
Mike
Mike
