- Apr 19, 2005
- Aix-en-Pce | France
E6700ES @4951MHz under 2-Stager
SYSTEM
CPU: Quent's E6700ES 5B1
MoBo: Asus P5B-DLX WiFi
RAM: Super Talent T800UX1GC4
OS: Windows XP Professional SP2
HDD: Western Digital IDE 80Gb
UPDATE
5182MHz
http://valid.x86-secret.com/show_oc?id=134250
4951MHz
Vcore= 1.81V (higher volts didn't give any improvement)
Vmch= 1.71V (it couldn't go over without making reboots)
Vddr= 2.70V (didn't try with more volts )
Normal mode with Green Olive scheme (Reg keys* + Maxmem=600): best run was achieved in 10.390s
*Among others, I've used these dword values:
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Session Manager\Executive]
"AdditionalCriticalWorkerThreads"=dword:00000000
"AdditionalDelayedWorkerThreads"=dword:00000000
"DefaultNumberOfWorkerThreads"=dword:00000001
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control]
"PriorityControl"=dword:00000002 (Foreground windows have quantums three times as long as other windows)
SYSTEM
UPDATE
5182MHz
4951MHz
Cooling: H2O
I've spent the last two days trying to select the best tweaks for Super PI. In fact, benching Super PI with C2D is very different than with A64. I was quite confident with my good old tweaks but I must confess that I'm a noob now for tweaking Super PI while running a C2D.
The CPU was cooled by an homemade watercooling system and only needed 1.4Vcore to operate within @3600MHz to 3680MHz.
Normal mode with Olive Green color scheme (Tweaks: modified registery keys + Maxmem=600): best run achieved in 13.797s
Normal mode (Tweaks: modified registery keys + No page file + Maxmem=600 + Copywaza=1.6Gb): single run achieved in 14m 37.844s
Cooling: Cascade (R290+R170 refrigerants, 8082+7950Btu/h rotaries compressors, @ about -100°C)
But today I've put the bad baby under 2-Stager to begin serious things... My motherboard is fully volt-modded but I didn't tune the Vmod trimmers yet and only set voltage settings to the max instead of the CPU which vcore has been set to 1.60V 'only'.
Take a look a the temp
Normal mode with Olive Green color scheme (Tweaks: modified registery keys + Maxmem=600): best run achieved in 10.703s
http://valid.x86-secret.com/show_oc?id=132820
I've to find more useful tweaks but the next step is to overclock a little bit more...
