- Nov 24, 2002
Hi guys,
I am looking for a specific paragraph in an RFC that states what characters are allowable in email addresses - namely stating that the '&' character isn't allowed.
I found RFC 2822 - but I can't quite understand it...
This section referring to 'atoms':
3.4.1. Addr-spec specification
An addr-spec is a specific Internet identifier that contains a
locally interpreted string followed by the at-sign character ("@",
ASCII value 64) followed by an Internet domain. The locally
interpreted string is either a quoted-string or a dot-atom. If the
string can be represented as a dot-atom (that is, it contains no
characters other than atext characters or "." surrounded by atext
characters), then the dot-atom form SHOULD be used and the
quoted-string form SHOULD NOT be used. Comments and folding white
space SHOULD NOT be used around the "@" in the addr-spec.
addr-spec = local-part "@" domain
local-part = dot-atom / quoted-string / obs-local-part
domain = dot-atom / domain-literal / obs-domain
domain-literal = [CFWS] "[" *([FWS] dcontent) [FWS] "]" [CFWS]
dcontent = dtext / quoted-pair
dtext = NO-WS-CTL / ; Non white space controls
%d33-90 / ; The rest of the US-ASCII
%d94-126 ; characters not including "[",
; "]", or "\"
The domain portion identifies the point to which the mail is
delivered. In the dot-atom form, this is interpreted as an Internet
domain name (either a host name or a mail exchanger name) as
described in [STD3, STD13, STD14]. In the domain-literal form, the
domain is interpreted as the literal Internet address of the
particular host. In both cases, how addressing is used and how
messages are transported to a particular host is covered in the mail
transport document [RFC2821]. These mechanisms are outside of the
scope of this document.
The local-part portion is a domain dependent string. In addresses,
it is simply interpreted on the particular host as a name of a
particular mailbox.
seems to be the part that explains it, but I can't see how. Can some kind techie break it down for me?
; "]", or "\"
particular mailbox.
