http://www.newegg.ca/Product/Produc...2&cm_re=970_gtx_sc-_-1FT-001K-00002-_-Product
Hi, so i am going to water cool my 970 GTX SC, and just wanted to know if the steps that i am going to go through with is proper?
The method i am going to use to watercool my 970gtx is going to be a little bit crude, but it should work since i did this with my 760gtx card in the past, which worked fine and got some good results.
This is the method i am speaking of: http://www.overclock.net/t/1203528/official-nvidia-gpu-mod-club-aka-the-mod
As you can see in that link it is a zip tie method. I just wanted to know what i am doing is okay for my 970gtx? Since this is more of a powerful card VS my past 760gtx card the process i am going to go through with is okay?
In the past i just added a 80mm fan on top of where the video memory is on the 760gtx card that i use to have to cool the VM and it seem to be working fine. Just wanted to know if i use the same process and if thats okay if i do the same with my 970gtx 4gb card?
