- Dec 13, 2003
- Saint Louis, MO USA
Yep, you read that correctly. I used an Acrylic football display case to house an external water cooling system.
I've long debated what to do about my rediculously loud, frustratingly unstable computer. I tried using some of the best air cooling solutions out there, but the noise was driving me nuts. I discovered watercooling, and being the creative type, I decided to embark on my own design.
The basics of the system are not that unusual really: Pump, Radiator, CPU water block, GPU water block and Reservoir. However, I decided I wanted an external system that would hold large cooling components, such as a Chevy heater core, a MAG 3 pump, a large reservoir, with room for fans.
First, some initial info:
Intel P4 2.4C
Asus P4C800 Deluxe
Corsair PC3700 DDR memory
ATI All In Wonder 9800 Pro (and, yes, it's water cooled)
2 unremarkable IDE hard drives, CD roms and such.
All of this crammed into a Ahanix Platinum Pro ATX case.
Air cooling consisted of the two case fans that came with the case, a Zalman 7000A-ALCU CPU cooler, and dual fan generic power supply from CompUSA.
Well, there wasn't enough room in the Ahanix case for a "real" water cooling system. The tiny ones with 3/8" tubing seemed too whimpy for my taste, so I opted for an external 1/2" tubing solution.
After much searching, I happened across an ebay'er selling acrylic football display cases:
(continued on next post)
Intel P4 2.4C
Asus P4C800 Deluxe
