- Jan 3, 2011
- California
I'm in the market for buying myself a graduation present, but I'm having trouble trying to decide which card to get. I have 3 monitors at 1920x1080 (only 2 running atm, have GTX 460 currently) and I think I want to give ATI a try for a single card solution to running all 3 monitors.
I was looking at the XFX DD line of cards and am debating either going R7870 with room for Crossfire, the R7950 with possible room for Crossfire, or the R7970.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150605
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150588
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150586
I'm currently leaning towards the 7870 since it nearly matches the 7950 in many of the benchmarks, but I was worried about how the 3GB of VRAM on the 7950 would really help on an Eyefinity setup. The 7870 also has Dual-DVI so I wouldn't need to buy adapter cables.
I don't really have a set budget, I'm more just looking for the most cost effective solution to run my setup. Thanks for any input!
