- Apr 8, 2012
- Hagaman, N. Y.
Just received mine and installed it, much better design then stock Intel push pins.
The way CM has the fan clipped looks to be blowing rather then exhausting so I put the fan up top. Is this the best configuration? Its 90 fahrenheit in this upstairs bedroom (just turned the AC on so hopefully that improves soon).
According to speedfan 4.46 I'm seeing my gpu at 39C, hd at 30c, cpu cores ranging from 32 to 36c.
My two top 140mm fans are exhausting air out the top, this Hyper 212 evo fan is blowing air thru the fins downward. Is this whats known as the push-pull flow?
Have 2 140mm fans pulling air in front
Have 2 140mm fans exhausting at the top
Have 1 120mm rear exhaust fan
