- May 20, 2003
- Colleyville, TX
I have a mesh grill over each of the dual ports on my blower. I occasionally pick a few stray objects out of it... stuff like... post-its and rodents.
Also...
For those of you talking about typical push/pull methods... Blowers can't be made to run backwards. They pull in air through the middle of the axis and push it according to the surrounding chasis. Most blowers have a single outlet and a single inlet. The fan itself hardly moves any air unless mounted in a proper chasis. The shrouds are often made by aftermarket companies, depending on their needs. That is why most 'fan' manufacturers advertise their blower fans, not a completed blower chasis. It's the overstock / surplus dealers that get ahold of the 'finished' product.
SO... if you wanted a push / pull configuration with a blower, you would either need a blower with a standard axial fan, or some nifty mounting in which the side inlet of the radial fan mounted to the 'pull' side of the radiator. That would look really stupid though.
Also...
