Hello to all the programming geeks. Well, I neither have any programming experience nor attend any programming classes. However, I would like to buy some books and learn from it. Sad that, I had encountered several of difficulties and confused me indeed! The bellows are my faced problems, so hopefully can be solved with satisfy of answer.
a)Is Visual C++ same as C++?
b) What is C#? Does it more advance than C++?
c) What is J++? Which compiler does it used?
(Is it worth to learn J++?)
d) What is the best compiler for C++?
e) Can C++ program a DOS environment application?
f) So what should I learn? C# or C++?
g) Is VB.NET and C#.NET a new programming language?
h) Can VB.NET compiler compile the VB6 codes?
(If it can’t, then what compiler does VB.NET use?)
i) As you see, I need to learn VB6 or VB.NET?
j) What kind of languages does Microsoft Visual Studio.NET can compile?
k) Overall, which languages are the most powerful and useful? C#, C++, VB6, VB.NET or others?
