- Mar 7, 2008
Below was some testing I just did triggered on a discussion elsewhere about how much influence does storage performance has on game load times. That's when I thought, for now is loading time influenced by CPU speeds and will remain so until we get GPU offloading with directstorage 1.1? Before this point, I was of the opinion the CPU only needed to be fast enough to give the target fps in game. Now I'm thinking, if you really want to min/max your load times as well, going faster CPU might help. Has anyone else tested how CPUs affect game loading time?
Testing with the stand alone FFXIV: Endwalker benchmark, as it provides a load time indication and you can toggle the cache reset.
CPU: 11700k either stock (up to 5 GHz turbo for 1 core) or turbo off (max clock of 3.6 GHz on all cores)
GPU: 2070
Ram: 2133 4x16GB
Settings: 1360x768 Max (this isn't a high fps test, but I'm temporarily using a very old TV on this system!)
CPU stock (125W long term power limit)
Samsung 980 Pro load: 10.875s, 166.1 fps
Cached load: 6.186, 166.8 fps
CPU base (3.6 GHz)
Samsung 980 Pro load: 11.767s, 153.2 fps
Cached load: 7.105s, 155.5 fps
I think we can agree the Samsung 980 Pro is representative of a high end 4.0 SSD right? In either CPU state, the cached load (essentially ramdisk) is ball park 40% faster than from SSD. Comparing across the CPU states, off SSD was 8% slower with the downclocked CPU, and 14% slower from cache. So there are hints that even high end SSD speed here is not practically unlimited like a ramdisk.
GPU: 2070
Ram: 2133 4x16GB
CPU base (3.6 GHz)
