Hi all
I'm no noob to IT or forums. I've built PCs with CPU cooling fans, but not with liquids to date. I'm building a new kind of 3D printer. It's a UV liquid resin, top down setup and every layer is like a color photograph. The UV lamp is to be mounted beside the inkjet heads. That leaves me a very little space. There is only 50 mm x 32 mm x 10 mm in total. The UV panel is 2-3 mm thick leaving 7 or 8 mm for the block. I'm in Toronto. I already have a pump, radiator, hoses and connectors. The connectors are M5 0.8 90 degree bends. I carved an opening in the inkjet head enclosure and have run hoses into the enclosure, passed the inkjet head and out the top.
Is there any existing cpu/gpu cooling block that might fit those dimensions? In the meantime, I'm designing and 3D printing a block and gasket to hold the uv panel, in case I end up having it machined. If anyone knows someone in my area that can make such a block, I'd appreciate a contact too.
Thanks!
Mike
Thanks!
Mike
