Reply
Hi,
Hope this helps:
1) I have a new hard drive 640GB
2) I want two 320GB partitions on that drive ONE for Windows the other for Linux/Ubuntu. As some of us have now learned the OS is Linux on which Ubuntu ( my chosen distribution ) is packed into.
3) I think terminology here needs clarified, Im relatively new to Partition tech, so if 2 above is Dual Boot then that is what I planned, the hard drive is now divided into two equal parts with Windows NTFS on one partition and Linux/Ubuntu ext.4 on the other.
The problem Im running into now is, having run from the CD to install Ubuntu progress is fine up to the part where I need to Edit the partition. Im assumming you are familiar with the bar chart showing all partitions on the drive. To activate the install this is what Im doing....I highlight the partition on which I want Ubuntu installed, then I choose the correct file system ext.4 in this case, then I leave the Format box empty, then Change and choose Mount Point, /, ( not sure what to choose here but / got the process running )? Advise if this is incorrect and supply correct parameter, then install . Now, we get to the 'Who Are You' page, Ok, we enter the relevant details and hit the correct button to install the files...the files bar then shows progress...But...after 90% the progress bar stops with the message...' Ready When You Are'...what should I do now, please advise? FYI there is a greyed bar at this point which if you click on it opens a black window with tech text about the install process...the text means nothing to me but I wonder if I should be entering some code here as there is a flashing curser which does accept text?
I can uninstall XP from the Windows created partition and format the whole drive again without any partitions , reinstall XP and install Ubuntu using the CD install alongside other OS ( XP ) option but is this a buggy road to travel?
We are all learning here,
Berne
