QuietIce
Disabled
- May 7, 2006
- Anywhere but there
The catch is the ±1% accuracy. Anybody can throw a few parts together and stick a price tag on it but making a reliable and accurate product is a whole different ballgame ...
If there was enough of a demand at the right selling price SVC, Petra's, Frozen CPU, or (insert your favorite store) would have already jumped on the bandwagon ...Propaganda said:It's tough to believe that a entrepreneur (belonging to the OC/WC communities) did not see this opportunity and commission a solution under $40. I would jump on it and crunch some numbers but I do not have the starting capital for such a endeavor.
QuietIce said:If there was enough of a demand at the right selling price SVC, Petra's, Frozen CPU, or (insert your favorite store) would have already jumped on the bandwagon ...
billb said:I use this:
http://www.freshwatersystems.com/c-61-flow-meters.aspx
I have it on a valved by-pass loop so the 3/8 isn't an issue. Not real accurate, about +/-0.1gpm. The housing can be removed and the readout remotely mounted on a 5-1/4 inch bay cover.
The DigiFlow 8000T incorporates a microprocessor control circuit and a magnetic turbine sensor to calculate the flow rate and flow volume. The DigiFlow 8000T can monitor a single filter by flow rate or flow volume, which can be programmed by the user. The user can program it to either display the real flow rate or volume, or count down from the programmed flow rate or volume and generate a sound alert when it reaches the end.
Features:
* User can program the DigiFlow
* Monitors a single filter
* Power source is two AAA alkaline batteries which last for more than two years
* Status is automatically memorized when power is off
* Mainly for residential and industrial water treatment application
Specifications:
* Capacity counters: 1
* Flow rate reading: Yes
* Capacity setting range: 100-9900 gallons
* Timing setting range: 30-720 days
* Flow rate range: 0.3-3.5 gpm
* Accuracy: +/-5%
* Connection: 3/8" NPT
* Working temperature: 40-100°F
* Working pressure: 8-100 psi
* Unit: Gallon
* Power: 3 VDC, 2 x AAA Battery
* End of capacity buzzer alert: Yes
* Dimension: 74 W x 70 H x 52 T
Recommended Parts:
* 3/8" Straight, Elbow, or Swivel Elbow Male Connector
UmHelp said:that is a really high flow rate. It probably wouldn't even read anything at all in a watercooling situation with a normal pump.
If you think 0.83 GPM is really high then may I suggest you upgrade your pump?UmHelp said:that is a really high flow rate. It probably wouldn't even read anything at all in a watercooling situation with a normal pump. pretty cheap though and has 3/4in fittings if you got it would would have to get some comverters.
Measuring Range: 50 to 250 gallons per hour
Maximum Pressure: 210 pounds per square inch
Temperature Range: 50° to 95°F (10° to 35°C)
Connection: PT 3/4" (standard piping thread) 3/4" flexible water hose/tubing
Aquarium Style: Fresh or Saltwater
