- Aug 4, 2012
- State of Confusion (USA)
I understand that the FX 8150 supports 1866. Any foreseen problems going from 8 to 16 gigs of G.SKILL Ripjaws X Series DDR3 2133?
Lastly my water cooling is a stock XSPC Rasa RS360 full kit, I just upgraded the fans before I left. Will my water kit even handle this CPU? If so any over clocking potential?
I just want to make sure I'm thinking about everything before I order. As I'm not home yet but will be pritty soon.
Frag
Hi Frag,
I know I'm new here, but I'm not a rookie to OC'ing...
I've had a few FX chips and your OC will depend alot on the VID of the chip you get (no way of knowing until intalled).
Low VID chips clock higher but run hot, higher VID chips will run cooler and generally clock a little better on ambient temps.
Reguardless, your cooling should get you stable in the 4.5-4.7 range with an average chip...
I can't speak for running 16gb, but if the RipJawX 2133 kit your talking about are these:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231476
They run really well for me in a 2x4 kit, very stable @ 2230 9-11-10 with stock v's!
If you want to save a few $$$ don't be afraid to go with an 8120, my best FX is actually an 8120!
The only reason I'm running the 8150 is it runs a little cooler, but it only nets me ~50mhz in all reality...
BTW: Thanks for your service Bro!
