Hey,
I recently did an upgrade of my pc...
I bought a GA-970A-UD3 motherboard and a AMD FX-8350 Black Edition CPU
Everything seemed fine until i entered a game. After a whiloe of gaming my PC would crash:
all inputs and outputs of the pc would just stop (leds on mouse and keyboard turned off and screen had no signal). When i try to turn off my pc by holding the power button down it wouldn't turn off and also the reset switch didn't do anything. Only way to stop my pc was to flip the PSU switch.
Now i have been testing for 2 weeks with prime95 and HWinfo to see what is the problem.
normally i can run p95 for about 7 minutes until it crashes like before.
With a big external fan blowing into the open case i can run it for 2+ hours, longer i didn't test but it propably could, so it's obviously an overheating problem.
With HWinfo i closely inspect the temps in my pc, my system temp is always around 26 - 34 C. My cpu is 28 idle and max 48 C under 100% load with p95 torture test. The temp3 of my mobo is 26 C idle and slowly climbs from 55 till 60 C and then my pc crashes.
With the big fan it stays around 50 - 54 and it won't crash at all.
so my question: what should i do?
should i find another motherboard or buy better heatsinks?
thnx in advance
thnx in advance
