RTS has no real need for dpi switching. The benefit of the built in arm processor and storage is so that profiles stick with the mouse instead of needing to install software and set it up on the PC.
Suppose you wanted to quickly scroll through the battlefield to a place remote from your present location? Wouldn't the ability to increase the DPI be desirable then?
Speed isn't typically a concern in RTS, is it? Any RTS I've played I've never felt the need to have higher sense/dpi or wanted to switch/change it. FPS and TPP, absolutely.
If you have a need, then you do...
It just takes a tiny bit of critical thinking to figure out if you personally could benefit.
