Gentoo AMD64 Ati X850XT - startx doesn't work
Lifthanger
Wöschbach LMAO
Hi.
here it comes: another problem. ;)
I'm a noob, but after looking around the gentoo forums, I think I've got a feeling what infos could be needed, to help me. Unfortunately I didn't find anyone with the same problem.
System is amd64 (in sig), cflags are -march=k8 -pipe - O2 kernel is 2.6.12-r6
and ati-drivers are 8.14.13-r3
What I did so far after the basic installation was "emerge kdebase-startkde".
After following instructions on how to install the fglrx module I type startx:
The screen turns black a few times and there's only this text:
Problem solved
If you should happen to have the same problem:
I can "startx" as a user, but not as root.
Code:
Lifthanger ~ # startx
hostname: Unknown host
X Window System Version 6.8.2
Release Date: 9 February 2005
X Protocol Version 11, Revision 0, Release 6.8.2
Build Operating System: Linux 2.6.12-gentoo-r6 x86_64 [ELF]
Current Operating System: Linux Lifthanger 2.6.12-gentoo-r6 #4 Tue Aug 16 03:22:27 UTC 2005 x86_64
Build Date: 13 August 2005
        Before reporting problems, check http://wiki.X.Org
        to make sure that you have the latest version.
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Tue Aug 16 03:54:18 2005
(==) Using config file: "/etc/X11/xorg.conf"
Using vt 7
(WW) fglrx: No matching Device section for instance (BusID PCI:5:0:1) found
Could not init font path element /usr/X11R6/lib/X11/fonts/local/, removing from list!
waiting for X server to shut down
here's my xorg.conf which was generated with fglxconfig
below is what dmesg tells me and last but not least the log file created when
executing startx.
Code:
# File: xorg.conf
# File generated by fglrxconfig (C) ATI Technologies, a substitute for xf86config.
# Note by ATI: the below copyright notice is there for servicing possibly
# pending third party rights on the file format and the instance of this file.
# Copyright (c) 1999 by The XFree86 Project, Inc.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
# THE XFREE86 PROJECT BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
# WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF
# OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
# SOFTWARE.
# Except as contained in this notice, the name of the XFree86 Project shall
# not be used in advertising or otherwise to promote the sale, use or other
# dealings in this Software without prior written authorization from the
# XFree86 Project.
# Refer to the XF86Config(4/5) man page for details about the format of
# this file.
# DRI Section
Section "dri"
# Access to OpenGL ICD is allowed for all users:
    Mode 0666
# Access to OpenGL ICD is restricted to a specific user group:
#    Group 100    # users
#    Mode 0660
EndSection
# Module section -- this  section  is used to specify
# which dynamically loadable modules to load.
Section "Module"
# This loads the DBE extension module.
    Load        "dbe"  	# Double buffer extension
# This loads the miscellaneous extensions module, and disables
# initialisation of the XFree86-DGA extension within that module.
    SubSection  "extmod"
      Option    "omit xfree86-dga"   # don't initialise the DGA extension
    EndSubSection
# This loads the Type1 and FreeType font modules
    Load        "type1"
    Load        "freetype"
# This loads the GLX module
    Load        "glx"   # libglx.a
    Load        "dri"   # libdri.a
EndSection
# Files section.  This allows default font and rgb paths to be set
Section "Files"
# The location of the RGB database.  Note, this is the name of the
# file minus the extension (like ".txt" or ".db").  There is normally
# no need to change the default.
    RgbPath	"/usr/X11R6/lib/X11/rgb"
# Multiple FontPath entries are allowed (which are concatenated together),
# as well as specifying multiple comma-separated entries in one FontPath
# command (or a combination of both methods)
# If you don't have a floating point coprocessor and emacs, Mosaic or other
# programs take long to start up, try moving the Type1 and Speedo directory
# to the end of this list (or comment them out).
    FontPath   "/usr/X11R6/lib/X11/fonts/local/"
    FontPath   "/usr/X11R6/lib/X11/fonts/misc/"
    FontPath   "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
    FontPath   "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
    FontPath   "/usr/X11R6/lib/X11/fonts/Type1/"
#    FontPath   "/usr/X11R6/lib/X11/fonts/Speedo/"
    FontPath   "/usr/X11R6/lib/X11/fonts/75dpi/"
    FontPath   "/usr/X11R6/lib/X11/fonts/100dpi/"
# The module search path.  The default path is shown here.
#    ModulePath "/usr/X11R6/lib/modules"
EndSection
# Server flags section.
Section "ServerFlags"
# Uncomment this to cause a core dump at the spot where a signal is
# received.  This may leave the console in an unusable state, but may
# provide a better stack trace in the core dump to aid in debugging
#    Option "NoTrapSignals"
# Uncomment this to disable the <Crtl><Alt><BS> server abort sequence
# This allows clients to receive this key event.
#    Option "DontZap"
# Uncomment this to disable the <Crtl><Alt><KP_+>/<KP_-> mode switching
# sequences.  This allows clients to receive these key events.
#    Option "Dont Zoom"
# Uncomment this to disable tuning with the xvidtune client. With
# it the client can still run and fetch card and monitor attributes,
# but it will not be allowed to change them. If it tries it will
# receive a protocol error.
#    Option "DisableVidModeExtension"
# Uncomment this to enable the use of a non-local xvidtune client.
#    Option "AllowNonLocalXvidtune"
# Uncomment this to disable dynamically modifying the input device
# (mouse and keyboard) settings.
#    Option "DisableModInDev"
# Uncomment this to enable the use of a non-local client to
# change the keyboard or mouse settings (currently only xset).
#    Option "AllowNonLocalModInDev"
EndSection
# Input devices
# Core keyboard's InputDevice section
Section "InputDevice"
    Identifier	"Keyboard1"
    Driver	"kbd"
# For most OSs the protocol can be omitted (it defaults to "Standard").
# When using XQUEUE (only for SVR3 and SVR4, but not Solaris),
# uncomment the following line.
#    Option "Protocol"   "Xqueue"
    Option "AutoRepeat" "500 30"
# Specify which keyboard LEDs can be user-controlled (eg, with xset(1))
#    Option "Xleds"      "1 2 3"
#    Option "LeftAlt"    "Meta"
#    Option "RightAlt"   "ModeShift"
# To customise the XKB settings to suit your keyboard, modify the
# lines below (which are the defaults).  For example, for a non-U.S.
# keyboard, you will probably want to use:
#    Option "XkbModel"   "pc102"
# If you have a US Microsoft Natural keyboard, you can use:
#    Option "XkbModel"   "microsoft"
# Then to change the language, change the Layout setting.
# For example, a german layout can be obtained with:
#    Option "XkbLayout"  "de"
# or:
#    Option "XkbVariant" "nodeadkeys"
# If you'd like to switch the positions of your capslock and
# control keys, use:
#    Option "XkbOptions" "ctrl:swapcaps"
# These are the default XKB settings for XFree86
#    Option "XkbRules"   "xfree86"
#    Option "XkbModel"   "pc101"
#    Option "XkbLayout"  "us"
#    Option "XkbVariant" ""
#    Option "XkbOptions" ""
#    Option "XkbDisable"
    Option "XkbModel"	"pc104"
EndSection
# Core Pointer's InputDevice section
# Identifier and driver
    Identifier	"Mouse1"
    Driver "mouse"
    Option "Protocol"   "ImPS/2"
    Option "ZAxisMapping"   "4 5"
    Option "Device"     "/dev/input/mice"
# When using XQUEUE, comment out the above two lines, and uncomment
# the following line.
# Baudrate and SampleRate are only for some Logitech mice. In
# almost every case these lines should be omitted.
#    Option "BaudRate"   "9600"
#    Option "SampleRate" "150"
# Emulate3Buttons is an option for 2-button Microsoft mice
# Emulate3Timeout is the timeout in milliseconds (default is 50ms)
#    Option "Emulate3Buttons"
#    Option "Emulate3Timeout"    "50"
# ChordMiddle is an option for some 3-button Logitech mice
#    Option "ChordMiddle"
EndSection
# Other input device sections
# this is optional and is required only if you
# are using extended input devices.  This is for example only.  Refer
# to the XF86Config man page for a description of the options.
# Section "InputDevice"
#    Identifier  "Mouse2"
#    Driver      "mouse"
#    Option      "Protocol"      "MouseMan"
#    Option      "Device"        "/dev/mouse2"
# EndSection
#    Identifier "spaceball"
#    Driver     "magellan"
#    Option     "Device"         "/dev/cua0"
# EndSection
#    Identifier "spaceball2"
#    Driver     "spaceorb"
# EndSection
#    Identifier "touchscreen0"
#    Driver     "microtouch"
#    Option     "Device"         "/dev/ttyS0"
#    Option     "MinX"           "1412"
#    Option     "MaxX"           "15184"
#    Option     "MinY"           "15372"
#    Option     "MaxY"           "1230"
#    Option     "ScreenNumber"   "0"
#    Option     "ReportingMode"  "Scaled"
#    Option     "ButtonNumber"   "1"
#    Option     "SendCoreEvents"
# EndSection
#    Identifier "touchscreen1"
#    Driver     "elo2300"
#    Option     "MinX"           "231"
#    Option     "MaxX"           "3868"
#    Option     "MinY"           "3858"
#    Option     "MaxY"           "272"
#    Option     "ButtonThreshold"    "17"
# EndSection
# Monitor section
# Any number of monitor sections may be present
Section "Monitor"
    Identifier  "Monitor0"
    HorizSync   31.5 - 80.5
    VertRefresh 60 - 75
    Option "DPMS"
# === mode lines based on GTF ===
# VGA @ 100Hz
# Modeline "640x480@100" 43.163 640 680 744 848 480 481 484 509 +hsync +vsync
# SVGA @ 100Hz
# Modeline "800x600@100" 68.179 800 848 936 1072 600 601 604 636 +hsync +vsync
# XVGA @ 100Hz
# Modeline "1024x768@100" 113.309 1024 1096 1208 1392 768 769 772 814 +hsync +vsync
# 1152x864 @ 60Hz
# Modeline "1152x864@60" 81.642 1152 1216 1336 1520 864 865 868 895 +hsync +vsync
# 1152x864 @ 85Hz
# Modeline "1152x864@85" 119.651 1152 1224 1352 1552 864 865 868 907 +hsync +vsync
# 1152x864 @ 100Hz
# Modeline "1152x864@100" 143.472 1152 1232 1360 1568 864 865 868 915 +hsync +vsync
# 1280x960 @ 75Hz
# Modeline "1280x960@75" 129.859 1280 1368 1504 1728 960 961 964 1002 +hsync +vsync
# 1280x960 @ 100Hz
# Modeline "1280x960@100" 178.992 1280 1376 1520 1760 960 961 964 1017  +hsync +vsync
# SXGA @ 100Hz
# Modeline "1280x1024@100" 190.960 1280 1376 1520 1760 1024 1025 1028 1085 +hsync +vsync
# SPEA GDM-1950 (60Hz,64kHz,110MHz,-,-): 1280x1024 @ V-freq: 60.00 Hz, H-freq: 63.73 KHz
# Modeline "GDM-1950"  109.62  1280 1336 1472 1720  1024 1024 1026 1062 -hsync -vsync
# 1600x1000 @ 60Hz
# Modeline "1600x1000" 133.142 1600 1704 1872 2144 1000 1001 1004 1035 +hsync +vsync
# 1600x1000 @ 75Hz
# Modeline "1600x1000" 169.128 1600 1704 1880 2160 1000 1001 1004 1044 +hsync +vsync
# 1600x1000 @ 85Hz
# Modeline "1600x1000" 194.202 1600 1712 1888 2176 1000 1001 1004 1050 +hsync +vsync
# 1600x1000 @ 100Hz
# Modeline "1600x1000" 232.133 1600 1720 1896 2192 1000 1001 1004 1059 +hsync +vsync
# 1600x1024 @ 60Hz
# Modeline "1600x1024" 136.385 1600 1704 1872 2144 1024 1027 1030 1060 +hsync +vsync
# 1600x1024 @ 75Hz
# Modeline "1600x1024" 174.416 1600 1712 1888 2176 1024 1025 1028 1069 +hsync +vsync
# 1600x1024 @ 76Hz
# Modeline "1600x1024" 170.450 1600 1632 1792 2096 1024 1027 1030 1070 +hsync +vsync
# 1600x1024 @ 85Hz
# Modeline "1600x1024" 198.832 1600 1712 1888 2176 1024 1027 1030 1075 +hsync +vsync
# 1920x1080 @ 60Hz
# Modeline "1920x1080" 172.798 1920 2040 2248 2576 1080 1081 1084 1118 -hsync -vsync
# 1920x1080 @ 75Hz
# Modeline "1920x1080" 211.436 1920 2056 2264 2608 1080 1081 1084 1126 +hsync +vsync
# 1920x1200 @ 60Hz
# Modeline "1920x1200" 193.156 1920 2048 2256 2592 1200 1201 1203 1242 +hsync +vsync
# 1920x1200 @ 75Hz
# Modeline "1920x1200" 246.590 1920 2064 2272 2624 1200 1201 1203 1253 +hsync +vsync
# 2048x1536 @ 60
# Modeline "2048x1536" 266.952 2048 2200 2424 2800 1536 1537 1540 1589 +hsync +vsync
# 2048x1536 @ 60
# 1400x1050 @ 60Hz M9 Laptop mode
# ModeLine "1400x1050" 122.000 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync
# 1920x2400 @ 25Hz for IBM T221, VS VP2290 and compatible display devices
# Modeline "1920x2400@25" 124.620 1920 1928 1980 2048 2400 2401 2403 2434 +hsync +vsync
# 1920x2400 @ 30Hz for IBM T221, VS VP2290 and compatible display devices
# Modeline "1920x2400@30" 149.250 1920 1928 1982 2044 2400 2402 2404 2434 +hsync +vsync
EndSection
# Graphics device section
# Any number of graphics device sections may be present
# Standard VGA Device:
Section "Device"
    Identifier  "Standard VGA"
    VendorName  "Unknown"
    BoardName   "Unknown"
# The chipset line is optional in most cases.  It can be used to override
# the driver's chipset detection, and should not normally be specified.
#    Chipset     "generic"
# The Driver line must be present.  When using run-time loadable driver
# modules, this line instructs the server to load the specified driver
# module.  Even when not using loadable driver modules, this line
# indicates which driver should interpret the information in this section.
    Driver      "vga"
# The BusID line is used to specify which of possibly multiple devices
# this section is intended for.  When this line isn't present, a device
# section can only match up with the primary video device.  For PCI
# devices a line like the following could be used.  This line should not
# normally be included unless there is more than one video device
# installed.
#    BusID       "PCI:0:10:0"
#    VideoRam    256
#    Clocks      25.2 28.3
EndSection
# === ATI device section ===
Section "Device"
    Identifier                          "ATI Graphics Adapter"
    Driver                              "fglrx"
# ### generic DRI settings ###
# === disable PnP Monitor  ===
    #Option                              "NoDDC"
# === disable/enable XAA/DRI ===
    Option "no_accel"                   "no"
    Option "no_dri"                     "no"
# === misc DRI settings ===
    Option "mtrr"                       "off" # disable DRI mtrr mapper, driver has its own code for mtrr
# ### FireGL DDX driver module specific settings ###
# === Screen Management ===
    Option "DesktopSetup"               "0x00000000"
    Option "MonitorLayout"              "AUTO, AUTO"
    Option "IgnoreEDID"                 "off"
    Option "HSync2"                     "unspecified"
    Option "VRefresh2"                  "unspecified"
    Option "ScreenOverlap"              "0"
# === TV-out Management ===
    Option "NoTV"                       "yes"
    Option "TVStandard"                 "NTSC-M"
    Option "TVHSizeAdj"                 "0"
    Option "TVVSizeAdj"                 "0"
    Option "TVHPosAdj"                  "0"
    Option "TVVPosAdj"                  "0"
    Option "TVHStartAdj"                "0"
    Option "TVColorAdj"                 "0"
    Option "GammaCorrectionI"           "0x00000000"
    Option "GammaCorrectionII"          "0x00000000"
# === OpenGL specific profiles/settings ===
    Option "Capabilities"               "0x00000000"
# === Video Overlay for the Xv extension ===
    Option "VideoOverlay"               "on"
# === OpenGL Overlay ===
# Note: When OpenGL Overlay is enabled, Video Overlay
#       will be disabled automatically
    Option "OpenGLOverlay"              "off"
# === Center Mode (Laptops only) ===
    Option "CenterMode"                 "off"
# === Pseudo Color Visuals (8-bit visuals) ===
    Option "PseudoColorVisuals"         "off"
# === QBS Management ===
    Option "Stereo"                     "off"
    Option "StereoSyncEnable"           "1"
# === FSAA Management ===
    Option "FSAAEnable"                 "no"
    Option "FSAAScale"                  "1"
    Option "FSAADisableGamma"           "no"
    Option "FSAACustomizeMSPos"         "no"
    Option "FSAAMSPosX0"                "0.000000"
    Option "FSAAMSPosY0"                "0.000000"
    Option "FSAAMSPosX1"                "0.000000"
    Option "FSAAMSPosY1"                "0.000000"
    Option "FSAAMSPosX2"                "0.000000"
    Option "FSAAMSPosY2"                "0.000000"
    Option "FSAAMSPosX3"                "0.000000"
    Option "FSAAMSPosY3"                "0.000000"
    Option "FSAAMSPosX4"                "0.000000"
    Option "FSAAMSPosY4"                "0.000000"
    Option "FSAAMSPosX5"                "0.000000"
    Option "FSAAMSPosY5"                "0.000000"
# === Misc Options ===
    Option "UseFastTLS"                 "0"
    Option "BlockSignalsOnLock"         "on"
    Option "UseInternalAGPGART"         "yes"
    Option "ForceGenericCPU"            "no"
#    BusID "PCI:1:0:0"    # no device found at config time
    Screen 0
EndSection
# Screen sections
# Any number of screen sections may be present.  Each describes
# the configuration of a single screen.  A single specific screen section
# may be specified from the X server command line with the "-screen"
# option.
Section "Screen"
    Identifier  "Screen0"
    Device      "ATI Graphics Adapter"
    Monitor     "Monitor0"
    DefaultDepth 24
    #Option "backingstore"
    Subsection "Display"
        Depth       24
        Modes       "640x480"
        ViewPort    0 0  # initial origin if mode is smaller than desktop
#        Virtual     1280 1024
    EndSubsection
EndSection
# ServerLayout sections.
# Any number of ServerLayout sections may be present.  Each describes
# the way multiple screens are organised.  A specific ServerLayout
# section may be specified from the X server command line with the
# "-layout" option.  In the absence of this, the first section is used.
# When now ServerLayout section is present, the first Screen section
# is used alone.
Section "ServerLayout"
# The Identifier line must be present
    Identifier  "Server Layout"
# Each Screen line specifies a Screen section name, and optionally
# the relative position of other screens.  The four names after
# primary screen name are the screens to the top, bottom, left and right
# of the primary screen.
    Screen "Screen0"
# Each InputDevice line specifies an InputDevice section name and
# optionally some options to specify the way the device is to be
# used.  Those options include "CorePointer", "CoreKeyboard" and
# "SendCoreEvents".
    InputDevice "Mouse1" "CorePointer"
    InputDevice "Keyboard1" "CoreKeyboard"
EndSection
### EOF ###
Code:
Bootdata ok (command line is root=/dev/sda3)
Linux version 2.6.12-gentoo-r6 (root@Lifthanger) (gcc version 3.4.3 20041125 (Gentoo 3.4.3-r1, ssp-3.4.3-0, pie-8.7.7)) #4 Tue Aug 16 03:22:27 UTC 2005
BIOS-provided physical RAM map:
 BIOS-e820: 0000000000000000 - 000000000009f800 (usable)
 BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved)
 BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
 BIOS-e820: 0000000000100000 - 000000003fff0000 (usable)
 BIOS-e820: 000000003fff0000 - 000000003fff3000 (ACPI NVS)
 BIOS-e820: 000000003fff3000 - 0000000040000000 (ACPI data)
 BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
 BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
ACPI: RSDP (v000 Nvidia                                ) @ 0x00000000000f7fb0
ACPI: RSDT (v001 Nvidia AWRDACPI 0x42302e31 AWRD 0x00000000) @ 0x000000003fff3040
ACPI: FADT (v001 Nvidia AWRDACPI 0x42302e31 AWRD 0x00000000) @ 0x000000003fff30c0
ACPI: SRAT (v001 AMD    HAMMER   0x00000001 AMD  0x00000001) @ 0x000000003fff90c0
ACPI: MCFG (v001 Nvidia AWRDACPI 0x42302e31 AWRD 0x00000000) @ 0x000000003fff91c0
ACPI: MADT (v001 Nvidia AWRDACPI 0x42302e31 AWRD 0x00000000) @ 0x000000003fff9000
ACPI: DSDT (v001 NVIDIA AWRDACPI 0x00001000 MSFT 0x0100000e) @ 0x0000000000000000
On node 0 totalpages: 262128
  DMA zone: 4096 pages, LIFO batch:1
  Normal zone: 258032 pages, LIFO batch:31
  HighMem zone: 0 pages, LIFO batch:1
Nvidia board detected. Ignoring ACPI timer override.
ACPI: PM-Timer IO Port: 0x1008
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
Processor #0 15:15 APIC version 16
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] disabled)
ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 2, version 17, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
ACPI: INT_SRC_OVR (bus 0 bus_irq 14 global_irq 14 high edge)
ACPI: INT_SRC_OVR (bus 0 bus_irq 15 global_irq 15 high edge)
ACPI: IRQ9 used by override.
ACPI: IRQ14 used by override.
ACPI: IRQ15 used by override.
Setting APIC routing to flat
Using ACPI (MADT) for SMP configuration information
Allocating PCI resources starting at 40000000 (gap: 40000000:a0000000)
Checking aperture...
CPU 0: aperture @ c2000000 size 32 MB
Aperture from northbridge cpu 0 too small (32 MB)
No AGP bridge found
Built 1 zonelists
Kernel command line: root=/dev/sda3
Initializing CPU#0
PID hash table entries: 4096 (order: 12, 131072 bytes)
time.c: Using 3.579545 MHz PM timer.
time.c: Detected 2403.587 MHz processor.
time.c: Using PIT/TSC based timekeeping.
Console: colour VGA+ 80x25
Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
Memory: 1025900k/1048512k available (2857k kernel code, 21912k reserved, 1007k data, 152k init)
Calibrating delay loop... 4751.36 BogoMIPS (lpj=2375680)
Mount-cache hash table entries: 256
CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
CPU: L2 Cache: 512K (64 bytes/line)
CPU: AMD Athlon(tm) 64 Processor 3000+ stepping 00
Using local APIC timer interrupts.
Detected 16.691 MHz APIC timer.
testing NMI watchdog ... OK.
NET: Registered protocol family 16
PCI: Using configuration type 1
mtrr: v2.0 (20020519)
ACPI: Subsystem revision 20050309
ACPI: Interpreter enabled
ACPI: Using IOAPIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
PCI: Transparent bridge - 0000:00:09.0
Boot video device is 0000:05:00.0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.HUB0._PRT]
ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNK2] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNK3] (IRQs 3 4 *5 7 9 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNK4] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNK5] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LUBA] (IRQs 3 4 *5 7 9 10 11 12 14 15)
ACPI: PCI Interrupt Link [LUBB] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LMAC] (IRQs 3 *4 5 7 9 10 11 12 14 15)
ACPI: PCI Interrupt Link [LACI] (IRQs *3 4 5 7 9 10 11 12 14 15)
ACPI: PCI Interrupt Link [LMCI] (IRQs 3 4 5 7 9 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LSMB] (IRQs *3 4 5 7 9 10 11 12 14 15)
ACPI: PCI Interrupt Link [LUB2] (IRQs 3 4 5 7 9 *10 11 12 14 15)
ACPI: PCI Interrupt Link [LIDE] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LSID] (IRQs 3 4 5 7 9 *10 11 12 14 15)
ACPI: PCI Interrupt Link [LFID] (IRQs 3 4 5 7 9 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LPCA] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [APC1] (IRQs 16) *0, disabled.
ACPI: PCI Interrupt Link [APC2] (IRQs 17) *0, disabled.
ACPI: PCI Interrupt Link [APC3] (IRQs 18) *0, disabled.
ACPI: PCI Interrupt Link [APC4] (IRQs 19) *0, disabled.
ACPI: PCI Interrupt Link [APC5] (IRQs *16), disabled.
ACPI: PCI Interrupt Link [APCF] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [APCG] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [APCH] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [APCJ] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [APCK] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [APCS] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [APCL] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [APCZ] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [APSI] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [APSJ] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [APCP] (IRQs 20 21 22 23) *0, disabled.
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq".  If it helps, post a report
PCI-DMA: Disabling IOMMU.
IA32 emulation $Id: sys_ia32.c,v 1.32 2002/03/24 13:02:28 ak Exp $
Total HugeTLB memory allocated, 0
inotify device minor=63
Installing knfsd (copyright (C) 1996 [email][email protected][/email]).
PCI: Setting latency timer of device 0000:00:0b.0 to 64
pcie_portdrv_probe->Dev[005d:10de] has invalid IRQ. Check vendor BIOS
assign_interrupt_mode Found MSI capability
Allocate Port Service[pcie00]
PCI: Setting latency timer of device 0000:00:0c.0 to 64
PCI: Setting latency timer of device 0000:00:0d.0 to 64
PCI: Setting latency timer of device 0000:00:0e.0 to 64
Real Time Clock Driver v1.12
Linux agpgart interface v0.101 (c) Dave Jones
ACPI: Power Button (FF) [PWRF]
ACPI: Fan [FAN] (on)
ACPI: Thermal Zone [THRM] (40 C)
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
Serial: 8250/16550 driver $Revision: 1.90 $ 8 ports, IRQ sharing disabled
mice: PS/2 mouse device common for all mice
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered
Intel(R) PRO/1000 Network Driver - version 6.0.54-k2
Copyright (c) 1999-2004 Intel Corporation.
forcedeth.c: Reverse Engineered nForce ethernet driver. Version 0.35.
ACPI: PCI Interrupt Link [APCH] enabled at IRQ 23
ACPI: PCI Interrupt 0000:00:0a.0[A] -> Link [APCH] -> GSI 23 (level, low) -> IRQ 217
PCI: Setting latency timer of device 0000:00:0a.0 to 64
input: AT Translated Set 2 keyboard on isa0060/serio0
input: PS2++ Logitech MX Mouse on isa0060/serio1
eth0: forcedeth.c: subsystem: 010de:cb84 bound to 0000:00:0a.0
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
netconsole: not configured, aborting
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
NFORCE-CK804: IDE controller at PCI slot 0000:00:06.0
NFORCE-CK804: chipset revision 162
NFORCE-CK804: not 100% native mode: will probe irqs later
NFORCE-CK804: 0000:00:06.0 (rev a2) UDMA133 controller
    ide0: BM-DMA at 0xe000-0xe007, BIOS settings: hda:DMA, hdb:DMA
    ide1: BM-DMA at 0xe008-0xe00f, BIOS settings: hdc:DMA, hdd:DMA
Probing IDE interface ide0...
hda: _NEC DVD_RW ND-3520AW, ATAPI CD/DVD-ROM drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1...
Probing IDE interface ide2...
Probing IDE interface ide3...
Probing IDE interface ide4...
Probing IDE interface ide5...
hda: ATAPI 48X DVD-ROM DVD-R CD-R/RW drive, 2048kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
libata version 1.11 loaded.
sata_nv version 0.8
ACPI: PCI Interrupt Link [APSI] enabled at IRQ 22
ACPI: PCI Interrupt 0000:00:07.0[A] -> Link [APSI] -> GSI 22 (level, low) -> IRQ 225
PCI: Setting latency timer of device 0000:00:07.0 to 64
ata1: SATA max UDMA/133 cmd 0x9F0 ctl 0xBF2 bmdma 0xCC00 irq 225
ata2: SATA max UDMA/133 cmd 0x970 ctl 0xB72 bmdma 0xCC08 irq 225
ata1: no device found (phy stat 00000000)
scsi0 : sata_nv
ata2: no device found (phy stat 00000000)
scsi1 : sata_nv
ACPI: PCI Interrupt Link [APSJ] enabled at IRQ 21
ACPI: PCI Interrupt 0000:00:08.0[A] -> Link [APSJ] -> GSI 21 (level, low) -> IRQ 233
PCI: Setting latency timer of device 0000:00:08.0 to 64
ata3: SATA max UDMA/133 cmd 0x9E0 ctl 0xBE2 bmdma 0xB800 irq 233
ata4: SATA max UDMA/133 cmd 0x960 ctl 0xB62 bmdma 0xB808 irq 233
ata3: dev 0 cfg 49:2f00 82:346b 83:7fe9 84:4773 85:3468 86:3c01 87:4763 88:407f
ata3: dev 0 ATA, max UDMA/133, 488397168 sectors: lba48
nv_sata: Primary device added
nv_sata: Primary device removed
nv_sata: Secondary device added
nv_sata: Secondary device removed
ata3: dev 0 configured for UDMA/133
scsi2 : sata_nv
ata4: dev 0 cfg 49:2f00 82:346b 83:7d01 84:4003 85:3468 86:3c01 87:4003 88:407f
ata4: dev 0 ATA, max UDMA/133, 390721968 sectors: lba48
ata4: dev 0 configured for UDMA/133
scsi3 : sata_nv
  Vendor: ATA       Model: HDT722525DLA380   Rev: V44O
  Type:   Direct-Access                      ANSI SCSI revision: 05
  Vendor: ATA       Model: ST3200822AS       Rev: 3.01
SCSI device sda: 488397168 512-byte hdwr sectors (250059 MB)
SCSI device sda: drive cache: write back
 sda: sda1 sda2 sda3
Attached scsi disk sda at scsi2, channel 0, id 0, lun 0
SCSI device sdb: 390721968 512-byte hdwr sectors (200050 MB)
SCSI device sdb: drive cache: write back
 sdb: sdb1 sdb2
Attached scsi disk sdb at scsi3, channel 0, id 0, lun 0
usbmon: debugs is not available
ACPI: PCI Interrupt Link [APCL] enabled at IRQ 20
ACPI: PCI Interrupt 0000:00:02.1[B] -> Link [APCL] -> GSI 20 (level, low) -> IRQ 50
PCI: Setting latency timer of device 0000:00:02.1 to 64
ehci_hcd 0000:00:02.1: EHCI Host Controller
ehci_hcd 0000:00:02.1: debug port 1
ehci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 1
ehci_hcd 0000:00:02.1: irq 50, io mem 0xfeb00000
PCI: cache line size of 64 is not supported by device 0000:00:02.1
ehci_hcd 0000:00:02.1: USB 2.0 initialized, EHCI 1.00, driver 10 Dec 2004
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 10 ports detected
ohci_hcd: 2004 Nov 08 USB 1.1 'Open' Host Controller (OHCI) Driver (PCI)
hub 1-0:1.0: over-current change on port 1
ACPI: PCI Interrupt Link [APCF] enabled at IRQ 23
ACPI: PCI Interrupt 0000:00:02.0[A] -> Link [APCF] -> GSI 23 (level, low) -> IRQ 217
PCI: Setting latency timer of device 0000:00:02.0 to 64
ohci_hcd 0000:00:02.0: OHCI Host Controller
ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 2
ohci_hcd 0000:00:02.0: irq 217, io mem 0xfebff000
hub 1-0:1.0: over-current change on port 2
hub 1-0:1.0: over-current change on port 3
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 10 ports detected
USB Universal Host Controller Interface driver v2.2
hub 1-0:1.0: over-current change on port 4
hub 1-0:1.0: over-current change on port 5
hub 1-0:1.0: over-current change on port 6
usbcore: registered new driver usblp
drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
Initializing USB Mass Storage driver...
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.01:USB HID core driver
Intel 810 + AC97 Audio, version 1.01, 03:21:50 Aug 16 2005
oprofile: using NMI interrupt.
NET: Registered protocol family 2
IP: routing cache hash table of 8192 buckets, 64Kbytes
TCP established hash table entries: 262144 (order: 9, 2097152 bytes)
TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
TCP: Hash tables configured (established 262144 bind 65536)
NET: Registered protocol family 10
IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
powernow-k8: Found 1 AMD Athlon 64 / Opteron processors (version 1.40.2)
powernow-k8: BIOS error - no PSB or ACPI _PSS objects
ACPI wakeup devices:
HUB0 XVR0 XVR1 XVR2 XVR3 USB0 USB2 MMAC MMCI PS2M PS2K
ACPI: (supports S0 S1 S3 S4 S5)
ReiserFS: sda3: found reiserfs format "3.6" with standard journal
ReiserFS: sda3: using ordered data mode
ReiserFS: sda3: journal params: device sda3, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
ReiserFS: sda3: checking transaction log (sda3)
ReiserFS: sda3: Using r5 hash to sort names
VFS: Mounted root (reiserfs filesystem) readonly.
Freeing unused kernel memory: 152k freed
Adding 506036k swap on /dev/sda2.  Priority:-1 extents:1
fglrx: module license 'Proprietary. (C) 2002 - ATI Technologies, Starnberg, GERMANY' taints kernel.
[fglrx] Maximum main memory to use for locked dma buffers: 920 MBytes.
ACPI: PCI Interrupt Link [APC3] enabled at IRQ 18
ACPI: PCI Interrupt 0000:05:00.0[A] -> Link [APC3] -> GSI 18 (level, low) -> IRQ 58
[fglrx] module loaded - fglrx 8.14.13 [Jun  8 2005] on minor 0
eth0: no IPv6 routers present
[fglrx] free  PCIe = 51118080
[fglrx] max   PCIe = 51118080
[fglrx] free  LFB = 128364544
[fglrx] max   LFB = 128364544
[fglrx] free  Inv = 134217728
[fglrx] max   Inv = 134217728
[fglrx] total Inv = 134217728
[fglrx] total TIM = 0
[fglrx] total FB  = 0
[fglrx] total PCIe = 16384
Code:
(==) Log file: "/var/log/Xorg.0.log", Time: Tue Aug 16 03:45:38 2005
(==) ServerLayout "Server Layout"
(**) |-->Screen "Screen0" (0)
(**) |   |-->Monitor "Monitor0"
(**) |   |-->Device "ATI Graphics Adapter"
(**) |-->Input Device "Mouse1"
(**) |-->Input Device "Keyboard1"
(**) FontPath set to "/usr/X11R6/lib/X11/fonts/local/,/usr/X11R6/lib/X11/fonts/misc/,/usr/X11R6/lib/X11/fonts/75dpi/:unscaled,/usr/X11R6/lib/X11/fonts/100dpi/:unscaled,/usr/X11R6/lib/X11/fonts/Type1/,/usr/X11R6/lib/X11/fonts/75dpi/,/usr/X11R6/lib/X11/fonts/100dpi/"
(**) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(==) ModulePath set to "/usr/lib64/modules"
(WW) Open APM failed (/dev/apm_bios) (No such file or directory)
(II) Module ABI versions:
	X.Org ANSI C Emulation: 0.2
	X.Org Video Driver: 0.7
	X.Org XInput driver : 0.4
	X.Org Server Extension : 0.2
	X.Org Font Renderer : 0.4
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/lib64/modules/fonts/libbitmap.a
(II) Module bitmap: vendor="X.Org Foundation"
	compiled for 6.8.2, module version = 1.0.0
	Module class: X.Org Font Renderer
	ABI class: X.Org Font Renderer, version 0.4
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/lib64/modules/libpcidata.a
(II) Module pcidata: vendor="X.Org Foundation"
	ABI class: X.Org Video Driver, version 0.7
Using vt 7
(--) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 10de,005e card 0000,0000 rev a3 class 05,80,00 hdr 00
(II) PCI: 00:01:0: chip 10de,0050 card 10de,cb84 rev a3 class 06,01,00 hdr 80
(II) PCI: 00:01:1: chip 10de,0052 card 10de,cb84 rev a2 class 0c,05,00 hdr 80
(II) PCI: 00:02:0: chip 10de,005a card 10de,cb84 rev a2 class 0c,03,10 hdr 80
(II) PCI: 00:02:1: chip 10de,005b card 10de,cb84 rev a3 class 0c,03,20 hdr 80
(II) PCI: 00:04:0: chip 10de,0059 card 10de,cb84 rev a2 class 04,01,00 hdr 00
(II) PCI: 00:06:0: chip 10de,0053 card 10de,cb84 rev a2 class 01,01,8a hdr 00
(II) PCI: 00:07:0: chip 10de,0054 card 10de,cb84 rev a3 class 01,01,85 hdr 00
(II) PCI: 00:08:0: chip 10de,0055 card 10de,cb84 rev a3 class 01,01,85 hdr 00
(II) PCI: 00:09:0: chip 10de,005c card 0000,0000 rev a2 class 06,04,01 hdr 01
(II) PCI: 00:0a:0: chip 10de,0057 card 10de,cb84 rev a3 class 06,80,00 hdr 00
(II) PCI: 00:0b:0: chip 10de,005d card 0000,0000 rev a3 class 06,04,00 hdr 01
(II) PCI: 00:0c:0: chip 10de,005d card 0000,0000 rev a3 class 06,04,00 hdr 01
(II) PCI: 00:0d:0: chip 10de,005d card 0000,0000 rev a3 class 06,04,00 hdr 01
(II) PCI: 00:0e:0: chip 10de,005d card 0000,0000 rev a3 class 06,04,00 hdr 01
(II) PCI: 00:18:0: chip 1022,1100 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:1: chip 1022,1101 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:2: chip 1022,1102 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:3: chip 1022,1103 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 01:06:0: chip 109e,036e card 0070,13eb rev 11 class 04,00,00 hdr 80
(II) PCI: 01:06:1: chip 109e,0878 card 0070,13eb rev 11 class 04,80,00 hdr 80
(II) PCI: 05:00:0: chip 1002,5d52 card 1002,0302 rev 00 class 03,00,00 hdr 80
(II) PCI: 05:00:1: chip 1002,5d72 card 1002,0303 rev 00 class 03,80,00 hdr 00
(II) PCI: End of PCI scan
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:1:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:9:0), (0,1,1), BCTRL: 0x0204 (VGA_EN is cleared)
(II) Bus 1 I/O range:
	[0] -1	0	0x0000a000 - 0x0000a0ff (0x100) IX[B]
	[1] -1	0	0x0000a400 - 0x0000a4ff (0x100) IX[B]
	[2] -1	0	0x0000a800 - 0x0000a8ff (0x100) IX[B]
	[3] -1	0	0x0000ac00 - 0x0000acff (0x100) IX[B]
(II) Bus 1 non-prefetchable memory range:
	[0] -1	0	0xfe900000 - 0xfe9fffff (0x100000) MX[B]
(II) Bus 1 prefetchable memory range:
	[0] -1	0	0xfea00000 - 0xfeafffff (0x100000) MX[B]
(II) PCI-to-PCI bridge:
(II) Bus 2: bridge is at (0:11:0), (0,2,2), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 2 I/O range:
	[0] -1	0	0x00009000 - 0x000090ff (0x100) IX[B]
	[1] -1	0	0x00009400 - 0x000094ff (0x100) IX[B]
	[2] -1	0	0x00009800 - 0x000098ff (0x100) IX[B]
	[3] -1	0	0x00009c00 - 0x00009cff (0x100) IX[B]
(II) Bus 2 non-prefetchable memory range:
	[0] -1	0	0xfe800000 - 0xfe8fffff (0x100000) MX[B]
(II) Bus 2 prefetchable memory range:
	[0] -1	0	0xfe700000 - 0xfe7fffff (0x100000) MX[B]
(II) Bus 3: bridge is at (0:12:0), (0,3,3), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 3 I/O range:
	[0] -1	0	0x00008000 - 0x000080ff (0x100) IX[B]
	[1] -1	0	0x00008400 - 0x000084ff (0x100) IX[B]
	[2] -1	0	0x00008800 - 0x000088ff (0x100) IX[B]
	[3] -1	0	0x00008c00 - 0x00008cff (0x100) IX[B]
(II) Bus 3 non-prefetchable memory range:
	[0] -1	0	0xfe600000 - 0xfe6fffff (0x100000) MX[B]
(II) Bus 3 prefetchable memory range:
	[0] -1	0	0xfe500000 - 0xfe5fffff (0x100000) MX[B]
(II) Bus 4: bridge is at (0:13:0), (0,4,4), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 4 I/O range:
	[0] -1	0	0x00007000 - 0x000070ff (0x100) IX[B]
	[1] -1	0	0x00007400 - 0x000074ff (0x100) IX[B]
	[2] -1	0	0x00007800 - 0x000078ff (0x100) IX[B]
	[3] -1	0	0x00007c00 - 0x00007cff (0x100) IX[B]
(II) Bus 4 non-prefetchable memory range:
	[0] -1	0	0xfe400000 - 0xfe4fffff (0x100000) MX[B]
(II) Bus 4 prefetchable memory range:
	[0] -1	0	0xfe300000 - 0xfe3fffff (0x100000) MX[B]
(II) Bus 5: bridge is at (0:14:0), (0,5,5), BCTRL: 0x000c (VGA_EN is set)
(II) Bus 5 I/O range:
	[0] -1	0	0x00006000 - 0x000060ff (0x100) IX[B]
	[1] -1	0	0x00006400 - 0x000064ff (0x100) IX[B]
	[2] -1	0	0x00006800 - 0x000068ff (0x100) IX[B]
	[3] -1	0	0x00006c00 - 0x00006cff (0x100) IX[B]
(II) Bus 5 non-prefetchable memory range:
	[0] -1	0	0xfe200000 - 0xfe2fffff (0x100000) MX[B]
(II) Bus 5 prefetchable memory range:
	[0] -1	0	0xd0000000 - 0xdfffffff (0x10000000) MX[B]
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:24:0), (0,0,5), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
	[0] -1	0	0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
	[0] -1	0	0x00000000 - 0xffffffff (0x100000000) MX[B]
(II) Bus 0 prefetchable memory range:
(II) Bus -1: bridge is at (0:24:1), (-1,-1,5), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus -1 I/O range:
(II) Bus -1 non-prefetchable memory range:
(II) Bus -1 prefetchable memory range:
(II) Bus -1: bridge is at (0:24:2), (-1,-1,5), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus -1: bridge is at (0:24:3), (-1,-1,5), BCTRL: 0x0008 (VGA_EN is set)
(--) PCI: (1:6:0) Brooktree Corporation Bt878 Video Capture rev 17, Mem @ 0xfeaff000/12
(--) PCI:*(5:0:0) ATI Technologies Inc unknown chipset (0x5d52) rev 0, Mem @ 0xd0000000/28, 0xfe2f0000/16, I/O @ 0x6c00/8
(--) PCI: (5:0:1) ATI Technologies Inc unknown chipset (0x5d72) rev 0, Mem @ 0xfe2e0000/16
(II) Addressable bus resource ranges are
	[1] -1	0	0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
	[0] -1	0	0xffe00000 - 0xffffffff (0x200000) MX[B](B)
	[1] -1	0	0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
	[2] -1	0	0x000f0000 - 0x000fffff (0x10000) MX[B]
	[3] -1	0	0x000c0000 - 0x000effff (0x30000) MX[B]
	[4] -1	0	0x00000000 - 0x0009ffff (0xa0000) MX[B]
	[5] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
	[6] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
	[0] -1	0	0xfeafe000 - 0xfeafefff (0x1000) MX[B]
	[1] -1	0	0xfebf9000 - 0xfebf9fff (0x1000) MX[B]
	[2] -1	0	0xfebfa000 - 0xfebfafff (0x1000) MX[B]
	[3] -1	0	0xfebfb000 - 0xfebfbfff (0x1000) MX[B]
	[4] -1	0	0xfebfd000 - 0xfebfdfff (0x1000) MX[B]
	[5] -1	0	0xfeb00000 - 0xfeb000ff (0x100) MX[B]
	[6] -1	0	0xfebff000 - 0xfebfffff (0x1000) MX[B]
	[7] -1	0	0xfe2f0000 - 0xfe2fffff (0x10000) MX[B](B)
	[8] -1	0	0xd0000000 - 0xdfffffff (0x10000000) MX[B](B)
	[9] -1	0	0xfeaff000 - 0xfeafffff (0x1000) MX[B](B)
	[10] -1	0	0x0000b400 - 0x0000b407 (0x8) IX[B]
	[11] -1	0	0x0000b800 - 0x0000b80f (0x10) IX[B]
	[12] -1	0	0x00000b60 - 0x00000b63 (0x4) IX[B]
	[13] -1	0	0x00000960 - 0x00000967 (0x8) IX[B]
	[14] -1	0	0x00000be0 - 0x00000be3 (0x4) IX[B]
	[15] -1	0	0x000009e0 - 0x000009e7 (0x8) IX[B]
	[16] -1	0	0x0000cc00 - 0x0000cc0f (0x10) IX[B]
	[17] -1	0	0x00000b70 - 0x00000b73 (0x4) IX[B]
	[18] -1	0	0x00000970 - 0x00000977 (0x8) IX[B]
	[19] -1	0	0x00000bf0 - 0x00000bf3 (0x4) IX[B]
	[20] -1	0	0x000009f0 - 0x000009f7 (0x8) IX[B]
	[21] -1	0	0x0000e000 - 0x0000e00f (0x10) IX[B]
	[22] -1	0	0x0000ec00 - 0x0000ecff (0x100) IX[B]
	[23] -1	0	0x0000f000 - 0x0000f0ff (0x100) IX[B]
	[24] -1	0	0x00001c40 - 0x00001c7f (0x40) IX[B]
	[25] -1	0	0x00001c00 - 0x00001c3f (0x40) IX[B]
	[26] -1	0	0x0000fc00 - 0x0000fc1f (0x20) IX[B]
	[27] -1	0	0x00006c00 - 0x00006cff (0x100) IX[B](B)
(II) Inactive PCI resource ranges:
	[0] -1	0	0xfe2e0000 - 0xfe2effff (0x10000) MX[B](B)
(II) Active PCI resource ranges after removing overlaps:
(II) Inactive PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
	[5] -1	0	0xfeafe000 - 0xfeafefff (0x1000) MX[B]
	[6] -1	0	0xfebf9000 - 0xfebf9fff (0x1000) MX[B]
	[7] -1	0	0xfebfa000 - 0xfebfafff (0x1000) MX[B]
	[8] -1	0	0xfebfb000 - 0xfebfbfff (0x1000) MX[B]
	[9] -1	0	0xfebfd000 - 0xfebfdfff (0x1000) MX[B]
	[10] -1	0	0xfeb00000 - 0xfeb000ff (0x100) MX[B]
	[11] -1	0	0xfebff000 - 0xfebfffff (0x1000) MX[B]
	[12] -1	0	0xfe2f0000 - 0xfe2fffff (0x10000) MX[B](B)
	[13] -1	0	0xd0000000 - 0xdfffffff (0x10000000) MX[B](B)
	[14] -1	0	0xfeaff000 - 0xfeafffff (0x1000) MX[B](B)
	[15] -1	0	0xfe2e0000 - 0xfe2effff (0x10000) MX[B](B)
	[16] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
	[17] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
	[18] -1	0	0x0000b400 - 0x0000b407 (0x8) IX[B]
	[19] -1	0	0x0000b800 - 0x0000b80f (0x10) IX[B]
	[20] -1	0	0x00000b60 - 0x00000b63 (0x4) IX[B]
	[21] -1	0	0x00000960 - 0x00000967 (0x8) IX[B]
	[22] -1	0	0x00000be0 - 0x00000be3 (0x4) IX[B]
	[23] -1	0	0x000009e0 - 0x000009e7 (0x8) IX[B]
	[24] -1	0	0x0000cc00 - 0x0000cc0f (0x10) IX[B]
	[25] -1	0	0x00000b70 - 0x00000b73 (0x4) IX[B]
	[26] -1	0	0x00000970 - 0x00000977 (0x8) IX[B]
	[27] -1	0	0x00000bf0 - 0x00000bf3 (0x4) IX[B]
	[28] -1	0	0x000009f0 - 0x000009f7 (0x8) IX[B]
	[29] -1	0	0x0000e000 - 0x0000e00f (0x10) IX[B]
	[30] -1	0	0x0000ec00 - 0x0000ecff (0x100) IX[B]
	[31] -1	0	0x0000f000 - 0x0000f0ff (0x100) IX[B]
	[32] -1	0	0x00001c40 - 0x00001c7f (0x40) IX[B]
	[33] -1	0	0x00001c00 - 0x00001c3f (0x40) IX[B]
	[34] -1	0	0x0000fc00 - 0x0000fc1f (0x20) IX[B]
	[35] -1	0	0x00006c00 - 0x00006cff (0x100) IX[B](B)
(II) LoadModule: "dbe"
(II) Loading /usr/lib64/modules/extensions/libdbe.a
(II) Module dbe: vendor="X.Org Foundation"
	Module class: X.Org Server Extension
	ABI class: X.Org Server Extension, version 0.2
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "extmod"
(II) Loading /usr/lib64/modules/extensions/libextmod.a
(II) Module extmod: vendor="X.Org Foundation"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "type1"
(II) Loading /usr/lib64/modules/fonts/libtype1.a
(II) Module type1: vendor="X.Org Foundation"
	compiled for 6.8.2, module version = 1.0.2
(II) Loading font Type1
(II) Loading font CID
(II) LoadModule: "freetype"
(II) Loading /usr/lib64/modules/fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
	compiled for 6.8.2, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: "glx"
(II) Loading /usr/lib64/modules/extensions/libglx.a
(II) Module glx: vendor="X.Org Foundation"
(II) Loading sub module "GLcore"
(II) LoadModule: "GLcore"
(II) Loading /usr/lib64/modules/extensions/libGLcore.a
(II) Module GLcore: vendor="X.Org Foundation"
(II) Loading extension GLX
(II) LoadModule: "dri"
(II) Loading /usr/lib64/modules/extensions/libdri.a
(II) Module dri: vendor="X.Org Foundation"
(II) Loading sub module "drm"
(II) LoadModule: "drm"
(II) Loading /usr/lib64/modules/linux/libdrm.a
(II) Module drm: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: "fglrx"
(II) Loading /usr/lib64/modules/drivers/fglrx_drv.o
(II) Module fglrx: vendor="FireGL - ATI Technologies Inc."
	compiled for 6.8.0, module version = 8.14.13
	Module class: X.Org Video Driver
(II) LoadModule: "mouse"
(II) Loading /usr/lib64/modules/input/mouse_drv.o
(II) Module mouse: vendor="X.Org Foundation"
	Module class: X.Org XInput Driver
	ABI class: X.Org XInput driver, version 0.4
(II) LoadModule: "kbd"
(II) Loading /usr/lib64/modules/input/kbd_drv.o
(II) Module kbd: vendor="X.Org Foundation"
(II) ATI Radeon/FireGL: The following chipsets are supported:
	RADEON 9000/9000 PRO (RV250 4966), RADEON 9000 LE (RV250 4967),
	MOBILITY FireGL 9000 (M9 4C64), MOBILITY RADEON 9000 (M9 4C66),
	RADEON 9000 PRO (D9 4C67), RADEON 9250 (RV280 5960),
	RADEON 9200 (RV280 5961), RADEON 9200 SE (RV280 5964),
	MOBILITY RADEON 9200 (M9+ 5C61), MOBILITY RADEON 9200 (M9+ 5C63),
	FireGL 8800 (R200 5148), RADEON 8500 (R200 514C),
	RADEON 9100 (R200 514D), RADEON 8500 AIW (R200 4242),
	RADEON 9600 (RV350 4150), RADEON 9600 SE (RV350 4151),
	RADEON 9600 PRO (RV360 4152),
	MOBILITY RADEON 9600/9700 (M10/M11 4E50), RADEON 9500 (R300 4144),
	RADEON 9600 TX (R300 4146), FireGL Z1 (R300 4147),
	RADEON 9700 PRO (R300 4E44), RADEON 9500 PRO/9700 (R300 4E45),
	RADEON 9600 TX (R300 4E46), FireGL X1 (R300 4E47),
	RADEON 9800 SE (R350 4148), RADEON 9550 (RV350 4153),
	FireGL T2 (RV350 4154), RADEON 9800 PRO (R350 4E48),
	RADEON 9800 (R350 4E49), RADEON 9800 XT (R360 4E4A),
	FireGL X2-256/X2-256t (R350 4E4B),
	MOBILITY FireGL T2/T2e (M10/M11 4E54), RADEON X300 (RV370 5B60),
	RADEON X600 (RV380 5B62), FireGL V3100 (RV370 5B64),
	MOBILITY RADEON X300 (M22 5460), MOBILITY FireGL V3100 (M22 5464),
	RADEON X600 (RV380 3E50), FireGL V3200 (RV380 3E54),
	MOBILITY RADEON X600 (M24 3150), MOBILITY RADEON X300 (M22 3152),
	MOBILITY FireGL V3200 (M24 3154), RADEON X800 (R420 4A48),
	RADEON X800 PRO (R420 4A49), RADEON X800 SE (R420 4A4A),
	RADEON X800 XT (R420 4A4B), RADEON X800 (R420 4A4C),
	FireGL X3-256 (R420 4A4D), MOBILITY RADEON 9800 (M18 4A4E),
	RADEON X800 XT Platinum Edition (R420 4A50), RADEON X800 (R423 5548),
	RADEON X800 PRO (R423 5549),
	RADEON X800 XT Platinum Edition (R423 554A),
	RADEON X800 SE (R423 554B), RADEON X800 XT (R423 5D57),
	FireGL V7100 (R423 5550), FireGL V5100 (R423 5551),
	MOBILITY RADEON X800 XT (M28 5D48), MOBILITY FireGL V5100 (M28 5D49),
	RADEON X800 XL (R430 554D), RADEON X800 (R430 554F),
	RADEON X850 XT Platinum Edition (R480 5D4D),
	RADEON X850 PRO (R480 5D4F), RADEON X850 XT (R480 5D52),
	MOBILITY FireGL V5000 (M26 564A), MOBILITY FireGL V5000 (M26 564B),
	FireGL V5000 (RV410 5E48), FireGL V3300 (RV410 5E49),
	RADEON X700 XT (RV410 5E4A), RADEON X700 PRO (RV410 5E4B),
	RADEON X700 SE (RV410 5E4C), RADEON X700 (RV410 5E4D),
	RADEON X700 (RV410 5E4F), MOBILITY RADEON X700 (M26 5652),
	MOBILITY RADEON X700 (M26 5653), RADEON 9100 IGP (RS300 5834),
	RADEON 9000 PRO/9100 PRO IGP (RS350 7834),
	MOBILITY RADEON 9000/9100 IGP (RS300M 5835)
(II) Primary Device is: PCI 05:00:0
(--) Assigning device section with no busID to primary device
(--) Chipset RADEON X850 XT (R480 5D52) found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) fglrx(0): pEnt->device->identifier=0x7190a0
(II) resource ranges after probing:
	[16] 0	0	0x000a0000 - 0x000affff (0x10000) MS[B]
	[17] 0	0	0x000b0000 - 0x000b7fff (0x8000) MS[B]
	[18] 0	0	0x000b8000 - 0x000bffff (0x8000) MS[B]
	[19] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
	[20] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
	[21] -1	0	0x0000b400 - 0x0000b407 (0x8) IX[B]
	[22] -1	0	0x0000b800 - 0x0000b80f (0x10) IX[B]
	[23] -1	0	0x00000b60 - 0x00000b63 (0x4) IX[B]
	[24] -1	0	0x00000960 - 0x00000967 (0x8) IX[B]
	[25] -1	0	0x00000be0 - 0x00000be3 (0x4) IX[B]
	[26] -1	0	0x000009e0 - 0x000009e7 (0x8) IX[B]
	[27] -1	0	0x0000cc00 - 0x0000cc0f (0x10) IX[B]
	[28] -1	0	0x00000b70 - 0x00000b73 (0x4) IX[B]
	[29] -1	0	0x00000970 - 0x00000977 (0x8) IX[B]
	[30] -1	0	0x00000bf0 - 0x00000bf3 (0x4) IX[B]
	[31] -1	0	0x000009f0 - 0x000009f7 (0x8) IX[B]
	[32] -1	0	0x0000e000 - 0x0000e00f (0x10) IX[B]
	[33] -1	0	0x0000ec00 - 0x0000ecff (0x100) IX[B]
	[34] -1	0	0x0000f000 - 0x0000f0ff (0x100) IX[B]
	[35] -1	0	0x00001c40 - 0x00001c7f (0x40) IX[B]
	[36] -1	0	0x00001c00 - 0x00001c3f (0x40) IX[B]
	[37] -1	0	0x0000fc00 - 0x0000fc1f (0x20) IX[B]
	[38] -1	0	0x00006c00 - 0x00006cff (0x100) IX[B](B)
	[39] 0	0	0x000003b0 - 0x000003bb (0xc) IS[B]
	[40] 0	0	0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) fglrx(0): === [R200PreInit] === begin, [s]
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/lib64/modules/libvgahw.a
(II) Module vgahw: vendor="X.Org Foundation"
	compiled for 6.8.2, module version = 0.1.0
(II) fglrx(0): PCI bus 5 card 0 func 0
(**) fglrx(0): Depth 24, (--) framebuffer bpp 32
(II) fglrx(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
(==) fglrx(0): Default visual is TrueColor
(**) fglrx(0): Option "NoAccel" "no"
(**) fglrx(0): Option "NoDRI" "no"
(**) fglrx(0): Option "Capabilities" "0x00000000"
(**) fglrx(0): Option "GammaCorrectionI" "0x00000000"
(**) fglrx(0): Option "GammaCorrectionII" "0x00000000"
(**) fglrx(0): Option "OpenGLOverlay" "off"
(**) fglrx(0): Option "VideoOverlay" "on"
(**) fglrx(0): Option "DesktopSetup" "0x00000000"
(**) fglrx(0): Option "MonitorLayout" "AUTO, AUTO"
(**) fglrx(0): Option "HSync2" "unspecified"
(**) fglrx(0): Option "VRefresh2" "unspecified"
(**) fglrx(0): Option "ScreenOverlap" "0"
(**) fglrx(0): Option "IgnoreEDID" "off"
(**) fglrx(0): Option "UseInternalAGPGART" "yes"
(**) fglrx(0): Option "Stereo" "off"
(**) fglrx(0): Option "StereoSyncEnable" "1"
(**) fglrx(0): Option "UseFastTLS" "0"
(**) fglrx(0): Option "BlockSignalsOnLock" "on"
(**) fglrx(0): Option "ForceGenericCPU" "no"
(**) fglrx(0): Option "CenterMode" "off"
(**) fglrx(0): Option "FSAAScale" "1"
(**) fglrx(0): Option "FSAAEnable" "no"
(**) fglrx(0): Option "FSAADisableGamma" "no"
(**) fglrx(0): Option "FSAACustomizeMSPos" "no"
(**) fglrx(0): Option "FSAAMSPosX0" "0.000000"
(**) fglrx(0): Option "FSAAMSPosY0" "0.000000"
(**) fglrx(0): Option "FSAAMSPosX1" "0.000000"
(**) fglrx(0): Option "FSAAMSPosY1" "0.000000"
(**) fglrx(0): Option "FSAAMSPosX2" "0.000000"
(**) fglrx(0): Option "FSAAMSPosY2" "0.000000"
(**) fglrx(0): Option "FSAAMSPosX3" "0.000000"
(**) fglrx(0): Option "FSAAMSPosY3" "0.000000"
(**) fglrx(0): Option "FSAAMSPosX4" "0.000000"
(**) fglrx(0): Option "FSAAMSPosY4" "0.000000"
(**) fglrx(0): Option "FSAAMSPosX5" "0.000000"
(**) fglrx(0): Option "FSAAMSPosY5" "0.000000"
(**) fglrx(0): Option "NoTV" "yes"
(**) fglrx(0): Option "TVStandard" "NTSC-M"
(**) fglrx(0): Option "TVHSizeAdj" "0"
(**) fglrx(0): Option "TVVSizeAdj" "0"
(**) fglrx(0): Option "TVHPosAdj" "0"
(**) fglrx(0): Option "TVVPosAdj" "0"
(**) fglrx(0): Option "TVHStartAdj" "0"
(**) fglrx(0): Option "TVColorAdj" "0"
(**) fglrx(0): Option "PseudoColorVisuals" "off"
(**) fglrx(0): Qbs disabled
(==) fglrx(0): FAST_SWAP disabled
(==) fglrx(0): RGB weight 888
(II) fglrx(0): Using 8 bits per RGB (8 bit DAC)
(**) fglrx(0): Gamma Correction for I is 0x00000000
(**) fglrx(0): Gamma Correction for II is 0x00000000
(==) fglrx(0): Buffer Tiling is ON
(II) Loading sub module "int10"
(II) LoadModule: "int10"
(II) Loading /usr/lib64/modules/linux/libint10.a
(II) Module int10: vendor="X.Org Foundation"
(II) fglrx(0): initializing int10
(II) fglrx(0): Primary V_BIOS segment is: 0xc000
(**) fglrx(0): Option "mtrr" "off"
(--) fglrx(0): Chipset: "RADEON X850 XT (R480 5D52)" (Chipset = 0x5d52)
(--) fglrx(0): (PciSubVendor = 0x1002, PciSubDevice = 0x0302)
(--) fglrx(0): board vendor info: original ATI graphics adapter
(--) fglrx(0): Linear framebuffer (phys) at 0xd0000000
(--) fglrx(0): MMIO registers at 0xfe2f0000
(--) fglrx(0): ChipExtRevID = 0x00
(--) fglrx(0): ChipIntRevID = 0x00
(--) fglrx(0): VideoRAM: 131072 kByte (64-bit SDR SDRAM)
(II) fglrx(0): board/chipset is supported by this driver (original ATI board)
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"
(II) Loading /usr/lib64/modules/libddc.a
(II) Module ddc: vendor="X.Org Foundation"
(II) Loading sub module "i2c"
(II) LoadModule: "i2c"
(II) Loading /usr/lib64/modules/libi2c.a
(II) Module i2c: vendor="X.Org Foundation"
	compiled for 6.8.2, module version = 1.2.0
(II) fglrx(0): I2C bus "DDC" initialized.
(II) fglrx(0): ATI Video BIOS revision 9 or later detected
(II) fglrx(0): Connector Layout from BIOS --------
(II) fglrx(0): Connector0: DDCType-2, DACType-0, TMDSType--1, ConnectorType-2
(II) fglrx(0): Connector1: DDCType-1, DACType-1, TMDSType-0, ConnectorType-3
(II) fglrx(0): All-In-Wonder card detected
(**) fglrx(0): MonitorLayout Option:
	Monitor1--Type AUTO, Monitor2--Type AUTO
(II) fglrx(0): I2C device "DDC:ddc2" registered at address 0xA0.
(II) fglrx(0): I2C device "DDC:ddc2" removed.
(II) fglrx(0): DDC detected on DDCType 2 with Monitor Type 1
(II) fglrx(0): Monitor1 EDID data ---------------------------
(II) fglrx(0): Manufacturer: SAM  Model: 80  Serial#: 1195913529
(II) fglrx(0): Year: 2002  Week: 44
(II) fglrx(0): EDID Version: 1.3
(II) fglrx(0): Analog Display Input,  Input Voltage Level: 0.700/0.300 V
(II) fglrx(0): Sync:  Separate  Composite  SyncOnGreenSerration on. V.Sync Pulse req. if CompSync or SyncOnGreen
(II) fglrx(0): Max H-Image Size [cm]: horiz.: 38  vert.: 31
(II) fglrx(0): Gamma: 2.40
(II) fglrx(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
(II) fglrx(0): First detailed timing is preferred mode
(II) fglrx(0): redX: 0.634 redY: 0.354   greenX: 0.304 greenY: 0.581
(II) fglrx(0): blueX: 0.143 blueY: 0.102   whiteX: 0.318 whiteY: 0.339
(II) fglrx(0): Supported VESA Video Modes:
(II) fglrx(0): 720x400@70Hz
(II) fglrx(0): 640x480@60Hz
(II) fglrx(0): 640x480@67Hz
(II) fglrx(0): 640x480@72Hz
(II) fglrx(0): 640x480@75Hz
(II) fglrx(0): 800x600@56Hz
(II) fglrx(0): 800x600@60Hz
(II) fglrx(0): 800x600@72Hz
(II) fglrx(0): 800x600@75Hz
(II) fglrx(0): 832x624@75Hz
(II) fglrx(0): 1024x768@60Hz
(II) fglrx(0): 1024x768@70Hz
(II) fglrx(0): 1024x768@75Hz
(II) fglrx(0): 1280x1024@75Hz
(II) fglrx(0): 1152x870@75Hz
(II) fglrx(0): Manufacturer's mask: 0
(II) fglrx(0): Supported Future Video Modes:
(II) fglrx(0): #0: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
(II) fglrx(0): #1: hsize: 1024  vsize 768  refresh: 60  vid: 16481
(II) fglrx(0): #2: hsize: 800  vsize 600  refresh: 60  vid: 16453
(II) fglrx(0): #3: hsize: 640  vsize 480  refresh: 60  vid: 16433
(II) fglrx(0): Supported additional Video Mode:
(II) fglrx(0): clock: 108.0 MHz   Image Size:  376 x 301 mm
(II) fglrx(0): h_active: 1280  h_sync: 1328  h_sync_end 1440 h_blank_end 1688 h_border: 0
(II) fglrx(0): v_active: 1024  v_sync: 1025  v_sync_end 1028 v_blanking: 1066 v_border: 0
(II) fglrx(0): Ranges: V min: 56  V max: 85 Hz, H min: 30  H max: 81 kHz, PixClock max 130 MHz
(II) fglrx(0): Monitor name: SyncMaster
(II) fglrx(0): Serial No: H4LTA07842
(II) fglrx(0): End of Monitor1 EDID data --------------------
(II) fglrx(0): DesktopSetup 0x0000
(**) fglrx(0):  PseudoColor visuals disabled
(**) fglrx(0): Overlay disabled
(II) fglrx(0): PLL parameters: rf=2700 rd=27 min=20000 max=50000
(==) fglrx(0): Using gamma correction (1.0, 1.0, 1.0)
(**) fglrx(0): Center Mode is disabled
(==) fglrx(0): TMDS coherent mode is enabled
(II) fglrx(0): Total 1 valid mode(s) found.
(--) fglrx(0): Virtual size is 640x480 (pitch 640)
(**) fglrx(0): *Default mode "640x480": 31.5 MHz (scaled from 0.0 MHz), 37.5 kHz, 75.0 Hz
(II) fglrx(0): Modeline "640x480"   31.50  640 656 720 840  480 481 484 500 -hsync -vsync
(--) fglrx(0): Display dimensions: (380, 310) mm
(--) fglrx(0): DPI set to (42, 39)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib64/modules/libfb.a
(II) Module fb: vendor="X.Org Foundation"
	ABI class: X.Org ANSI C Emulation, version 0.2
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Loading /usr/lib64/modules/libramdac.a
(II) Module ramdac: vendor="X.Org Foundation"
(**) fglrx(0): NoAccel = NO
(II) Loading sub module "xaa"
(II) LoadModule: "xaa"
(II) Loading /usr/lib64/modules/libxaa.a
(II) Module xaa: vendor="X.Org Foundation"
(==) fglrx(0): HPV inactive
(==) fglrx(0): FSAA enabled: NO
(**) fglrx(0): FSAA Gamma enabled
(**) fglrx(0): FSAA Multisample Position is fix
(**) fglrx(0): NoDRI = NO
(II) Loading sub module "fglrxdrm"
(II) LoadModule: "fglrxdrm"
(II) Loading /usr/lib64/modules/linux/libfglrxdrm.a
(II) Module fglrxdrm: vendor="FireGL - ATI Technologies Inc."
(II) fglrx(0): Depth moves disabled by default
(**) fglrx(0): Capabilities: 0x00000000
(**) fglrx(0): cpuFlags: 0x4000001f
(**) fglrx(0): cpuSpeedMHz: 0x00000963
(==) fglrx(0): OpenGL ClientDriverName: "fglrx_dri.so"
(**) fglrx(0): UseFastTLS=0
(**) fglrx(0): BlockSignalsOnLock=1
(==) fglrx(0): EnablePrivateBackZ = NO
(--) Depth 24 pixmap format is 32 bpp
(II) do I need RAC?  No, I don't.
(II) resource ranges after preInit:
	[0] 0	0	0xfe2f0000 - 0xfe2fffff (0x10000) MX[B]
	[1] 0	0	0xd0000000 - 0xdfffffff (0x10000000) MX[B]
	[2] -1	0	0xffe00000 - 0xffffffff (0x200000) MX[B](B)
	[3] -1	0	0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
	[4] -1	0	0x000f0000 - 0x000fffff (0x10000) MX[B]
	[5] -1	0	0x000c0000 - 0x000effff (0x30000) MX[B]
	[6] -1	0	0x00000000 - 0x0009ffff (0xa0000) MX[B]
	[7] -1	0	0xfeafe000 - 0xfeafefff (0x1000) MX[B]
	[8] -1	0	0xfebf9000 - 0xfebf9fff (0x1000) MX[B]
	[9] -1	0	0xfebfa000 - 0xfebfafff (0x1000) MX[B]
	[10] -1	0	0xfebfb000 - 0xfebfbfff (0x1000) MX[B]
	[11] -1	0	0xfebfd000 - 0xfebfdfff (0x1000) MX[B]
	[12] -1	0	0xfeb00000 - 0xfeb000ff (0x100) MX[B]
	[13] -1	0	0xfebff000 - 0xfebfffff (0x1000) MX[B]
	[14] -1	0	0xfe2f0000 - 0xfe2fffff (0x10000) MX[B](B)
	[15] -1	0	0xd0000000 - 0xdfffffff (0x10000000) MX[B](B)
	[16] -1	0	0xfeaff000 - 0xfeafffff (0x1000) MX[B](B)
	[17] -1	0	0xfe2e0000 - 0xfe2effff (0x10000) MX[B](B)
	[18] 0	0	0x000a0000 - 0x000affff (0x10000) MS[B]
	[19] 0	0	0x000b0000 - 0x000b7fff (0x8000) MS[B]
	[20] 0	0	0x000b8000 - 0x000bffff (0x8000) MS[B]
	[21] 0	0	0x00006c00 - 0x00006cff (0x100) IX[B]
	[22] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
	[23] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
	[24] -1	0	0x0000b400 - 0x0000b407 (0x8) IX[B]
	[25] -1	0	0x0000b800 - 0x0000b80f (0x10) IX[B]
	[26] -1	0	0x00000b60 - 0x00000b63 (0x4) IX[B]
	[27] -1	0	0x00000960 - 0x00000967 (0x8) IX[B]
	[28] -1	0	0x00000be0 - 0x00000be3 (0x4) IX[B]
	[29] -1	0	0x000009e0 - 0x000009e7 (0x8) IX[B]
	[30] -1	0	0x0000cc00 - 0x0000cc0f (0x10) IX[B]
	[31] -1	0	0x00000b70 - 0x00000b73 (0x4) IX[B]
	[32] -1	0	0x00000970 - 0x00000977 (0x8) IX[B]
	[33] -1	0	0x00000bf0 - 0x00000bf3 (0x4) IX[B]
	[34] -1	0	0x000009f0 - 0x000009f7 (0x8) IX[B]
	[35] -1	0	0x0000e000 - 0x0000e00f (0x10) IX[B]
	[36] -1	0	0x0000ec00 - 0x0000ecff (0x100) IX[B]
	[37] -1	0	0x0000f000 - 0x0000f0ff (0x100) IX[B]
	[38] -1	0	0x00001c40 - 0x00001c7f (0x40) IX[B]
	[39] -1	0	0x00001c00 - 0x00001c3f (0x40) IX[B]
	[40] -1	0	0x0000fc00 - 0x0000fc1f (0x20) IX[B]
	[41] -1	0	0x00006c00 - 0x00006cff (0x100) IX[B](B)
	[42] 0	0	0x000003b0 - 0x000003bb (0xc) IS[B]
	[43] 0	0	0x000003c0 - 0x000003df (0x20) IS[B]
(II) fglrx(0): UMM area:     0xd032d000 (size=0x07cc3000)
(II) fglrx(0): driver needs X.org 6.8.x
(II) fglrx(0): detected X.org 6.8.2
(II) Loading extension ATIFGLRXDRI
(II) fglrx(0): doing DRIScreenInit
drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is 5, (OK)
drmOpenByBusid: Searching for BusID PCI:5:0:0
drmOpenByBusid: drmOpenMinor returns 5
drmOpenByBusid: drmGetBusid reports
drmOpenDevice: node name is /dev/dri/card1
drmOpenDevice: open result is -1, (No such device)
drmOpenDevice: Open failed
drmOpenByBusid: drmOpenMinor returns -1023
drmOpenDevice: node name is /dev/dri/card2
drmOpenDevice: node name is /dev/dri/card3
drmOpenDevice: node name is /dev/dri/card4
drmOpenDevice: node name is /dev/dri/card5
drmOpenDevice: node name is /dev/dri/card6
drmOpenDevice: node name is /dev/dri/card7
drmOpenDevice: node name is /dev/dri/card8
drmOpenDevice: node name is /dev/dri/card9
drmOpenDevice: node name is /dev/dri/card10
drmOpenDevice: node name is /dev/dri/card11
drmOpenDevice: node name is /dev/dri/card12
drmOpenDevice: node name is /dev/dri/card13
drmOpenDevice: node name is /dev/dri/card14
drmGetBusid returned ''
(II) fglrx(0): [drm] DRM interface version 1.0
(II) fglrx(0): [drm] created "fglrx" driver at busid "PCI:5:0:0"
(II) fglrx(0): [drm] added 8192 byte SAREA at 0xffffc200001ac000
(II) fglrx(0): [drm] mapped SAREA 0xffffc200001ac000 to 0x2aaaab53e000
(II) fglrx(0): [drm] framebuffer handle = 0xd0000000
(II) fglrx(0): [drm] added 1 reserved context for kernel
(II) fglrx(0): DRIScreenInit done
(II) fglrx(0): Kernel Module Version Information:
(II) fglrx(0):     Name: fglrx
(II) fglrx(0):     Version: 8.14.13
(II) fglrx(0):     Date: Jun  8 2005
(II) fglrx(0):     Desc: ATI FireGL DRM kernel module
(II) fglrx(0): Kernel Module version matches driver.
(II) fglrx(0): Kernel Module Build Time Information:
(II) fglrx(0):     Build-Kernel UTS_RELEASE:        2.6.12-gentoo-r6
(II) fglrx(0):     Build-Kernel MODVERSIONS:        no
(II) fglrx(0):     Build-Kernel __SMP__:            no
(II) fglrx(0):     Build-Kernel PAGE_SIZE:          0x1000
(II) fglrx(0): [drm] register handle = 0xfe2f0000
(II) fglrx(0): [drm] ATIGART Table handle = 0xdfff0000
(II) fglrx(0): [pcie] 65536 kB allocated with handle 0x00000000
(II) fglrx(0): [drm] ringbuffer size = 0x00100000 bytes
(II) fglrx(0): [drm] DRM buffer queue setup: nbufs = 100 bufsize = 65536
(II) fglrx(0): [drm] texture shared area handle = 0xffffc20008975000
(II) fglrx(0): shared FSAAScale=1
(II) fglrx(0): DRI initialization successfull!
(II) fglrx(0): FBADPhys: 0xd0000000 FBMappedSize: 0x0032d000
(II) fglrx(0): FBMM initialized for area (0,0)-(640,1300)
(II) fglrx(0): FBMM auto alloc for area (0,0)-(640,480) (front color buffer - assumption)
(==) fglrx(0): Backing store disabled
(==) fglrx(0): Silken mouse enabled
(II) fglrx(0): Using hardware cursor (scanline 480)
(II) fglrx(0): Largest offscreen area available: 640 x 812
(**) Option "dpms"
(**) fglrx(0): DPMS enabled
(II) fglrx(0): Using XFree86 Acceleration Architecture (XAA)
	Screen to screen bit blits
	Solid filled rectangles
	8x8 mono pattern filled rectangles
	Solid Lines
	Dashed Lines
	Offscreen Pixmaps
	Setting up tile and stipple cache:
		30 128x128 slots
(II) fglrx(0): Acceleration enabled
(II) fglrx(0): X context handle = 0x00000001
(II) fglrx(0): [DRI] installation complete
(II) fglrx(0): Direct rendering enabled
(**) fglrx(0): Video overlay enabled on CRTC1
(II) Loading extension FGLRXEXTENSION
(II) Loading extension ATITVOUT
(==) RandR enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension LBX
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
(**) Option "Protocol" "ImPS/2"
(**) Mouse1: Device: "/dev/input/mice"
(**) Mouse1: Protocol: "ImPS/2"
(**) Option "CorePointer"
(**) Mouse1: Core Pointer
(**) Option "Device" "/dev/input/mice"
(==) Mouse1: Emulate3Buttons, Emulate3Timeout: 50
(**) Option "ZAxisMapping" "4 5"
(**) Mouse1: ZAxisMapping: buttons 4 and 5
(**) Mouse1: Buttons: 5
(**) Mouse1: SmartScroll: 1
(**) Option "CoreKeyboard"
(**) Keyboard1: Core Keyboard
(**) Option "Protocol" "standard"
(**) Keyboard1: Protocol: standard
(**) Option "AutoRepeat" "500 30"
(**) Option "XkbRules" "xfree86"
(**) Keyboard1: XkbRules: "xfree86"
(**) Option "XkbModel" "pc104"
(**) Keyboard1: XkbModel: "pc104"
(**) Option "XkbLayout" "de"
(**) Keyboard1: XkbLayout: "de"
(**) Option "CustomKeycodes" "off"
(**) Keyboard1: CustomKeycodes disabled
(II) XINPUT: Adding extended input device "Keyboard1" (type: KEYBOARD)
(II) XINPUT: Adding extended input device "Mouse1" (type: MOUSE)
(II) Mouse1: ps2EnableDataReporting: succeeded
Could not init font path element /usr/X11R6/lib/X11/fonts/local/, removing from list!
(II) fglrx(0): [drm] removed 1 reserved context for kernel
(II) fglrx(0): [drm] unmapping 8192 bytes of SAREA 0xffffc200001ac000 at 0x2aaaab53e000
What confuses me is, that the driver seems to be installed correctly, and there is no single error message in the log file.The fglrx module is installed which I tested with lsmod. so why doesn't xwindows come up?
These are large files, but I thought linux experienced guys know where to search. If someone wants to take a look through ssh, just pm me.
thanks for your time. :)
Try changing driver to "vesa" temporarily to see if it works with that. If it does, then you'll know it's the fglrx drivers.
Also, check what version of the ATI drivers you are using, and if they support the x850. That's a very new card.
using lspci I found my gfx card to be of type 5D52 which is listed as a supported device. You can check scrolling down the last code window with the xorg.log file. All supported chips are listed there.
Could you tell me, how to use the Vesa driver? Do I have to enable framebuffer devices in the kernel, to do so?
It seems as if older versions of the driver had problems with the kernel revision I'm using, but these are gone with my driver version.
Another thing is that some guys need AGPgart support in order to use xorg (using PCie!). But unfortunately I can't select agpgart as a module, because it's sort of preinstalled in the kernel (can't change the setting). Additionally there is no nvidia agp chipset listed.
Using a nforce4 board this seems very odd to me.
edit:
taken from the log file:
The quick and dirty way is to change the line in your /etc/X11/xorg.conf file that says Driver "fglrx" to read Driver "vesa". Vesa almost always works, although the special ATI modified config file may bork it.
Another thing you might try is to use the automatic X configuration utility. It doesn't always work, but sometimes it works quite well. Log in as root, type in xorgcfg. It will bring up some graphical panels. Just choose quit at this point, and it will ask if it should write the config file. Choose yes. Then try startx again. Hopefully, it will have autodetected your hardware.
There is also a semi-automatic utility to write xorg config files. This is xorgconfig. It will ask you questions rather than autodetecting things, and you can choose what driver to use. ati or vesa should work, although not as fast as fglrx.
I have little experience with the ATI drivers, as I use nvidia on all my machines. However, I did do an install with fglrx drivers and gentoo on a Dell Latitude. I remember it taking a few hours to get them working, but that they did work in the end. Rogerdugans has done a lot with the ati drivers on this forum, you might want to ask him for help.
I THINK I had a similar error in slackware with my Radeon9550. Not 100% sure it's the same error, but all I had to do was type "startx" a second time and it would load up just fine (I never figured out what was causing that :p).
thanks for your replies so far.
changing the driver to vesa did result in the same. The screen gets black.. I could see the X of the cursor for a moment and then it's gone.
using xorgcfg resulted in instant failure, saying i810 (module for integrated gfx on intel boards) isn't loaded. using xorgconfig didn't succeed either.
Could it be my monitor is on the wrong head? The card has one DVI and one normal connector, which I'm using. Doesn't make sense, as the wrong disply should stay black.
I'll start reading though threads by Rogerdugans about the matter.
edit: and of course I tried startx several times in a row ;)
I've just noticed, only xorg-X11 is merged, while xorg-server is masked and not installed. is this default, or do I have to unmask and install xorg-server?
edit: errmm it seems to work when I'm not logged in as root... hope it keeps working
i810 is the sound module I think, not video. I'm not 100% sure of that though. snd_intel8x0 is the sound module I use for my on board nforce 2 sound.
I have xorg-x11 installed on mine, but portage doesn't seem to know of the existence of xorg-server. Are you sure that's the package name?
thanks for your reply.
I've loaded the snd_intel8x0 module which supports my karajan audio on the DFI.
The Problem seems to be resolved... I have to startx as a user and not as root.
Dont tell me this is common knowledge ;).
All seems well at the moment as I'm starting to install my needed parts for KDE.
thanks for your time and efforts. I'll post here if I happen to run into another problem! :)
It's not quite normal. I can run X fine as root or as my regular login. Interesting that there is a difference. It's likely in one of the .x... files in your home directory, .xinitrc, .xserverrc, or something like that. Note that files beginning with . are hidden when you do an ls by default.
thank you! I'll tackle the problem tomorrow!
Got another hint, that it's just a "bad'" config file:
when I try to login as root using kdm a window pops up telling me:
"Root logins are not allowed"
I wish startx's console output had printed this out before ;).
It's possible it has something to do with the gui login manager restricting root logins. I have never used those login managers; I like to just boot to a command prompt, and then I start X if I want it, so I don't know how they work really.
I didn't find anything in these files, but it isn't important, because I'm not working as root anymore. Thanks for your help.
Gentoo is really fast... when I boot back to windows, I've got the feeling as if it's lagging.
Checking the task manager all the time ;).
Gentoo seems to make very good use of system memory... really nice.
There are still some minor questions, but I'll try to find some threads about it and not to bother you :).
One of the nicest things about Gentoo (NOT true of all linux distros) is that it installs ONLY what is absolutely necessary, and then what you tell it to. This makes for a very fast startup with very low resources used.
