"---Article is great and certainly something to consider but what other choice do users have other than MBM?
If you have a clock that's broken and cannot keep track of time accurately, and you can't afford another one, do you say, "It must be OK?" That's essentially what you're saying."
I was asking for other means of measurements. I asked a question. How do you derive a conclusion from a question?
"---but let's say it's true and Glaciators is the best heatsink.
We aren't saying it is."
Really? The Emperor Speaks?
"---Or should they all start drilling holes in their heatsink and place another thermistor in it?
If they need an accurate temperature reading, something along those lines would need to be done. However, most people don't need that level of precision; we put together that calculation so people could at least have an alternate means of checking their situation."
Are you absolutely positive that the calculation is accurate? How can it be? It depens on the system, thermal compounds, method used on applying compound, case fans. It seems even more unreliable than the MBM.
"How is it possible that there's world hunger? How is it possible that Windows crashes? How is it possible that Intel and Via chipsets have bugs in them. It is. Saying that there shouldn't be doesn't change the "is.""
You don't wanna hear my answer on these. In case you haven't noticed, it was just an expression.
"When something breaks in your house, for the next six months, do you say, "It shouldn't be broken." What does that do?"
Doesn't have nothing to do with what I said.
"This is like having a guy with very poor sight judging the Miss America contest, and you're saying it's the contestant's fault."
Beauty contest are never contestant's fault. If I'm the judge, yes, I make decision based on my vision and taste. It's matter of opinion and my opinion says this one doesn't look good. If my eye sights are bad, at least it's consistantly bad. I don't favor one contestant over the other like some do.
"Firestone made tires before the Model T. The tires work fine with other SUVs. They don't work so fine with Ford Explorers. On the other hand, Ford Explorers work fine with other tires. Again, it's not just one party's fault."
I didn't wanna spread into another subject but... Is the tire made before the Model T the tire in question? I don't think so. Tire in question is released well after Explorer. I'm not interested in determining who's at fault. I'm interested in solution. Is it cheaper for Explorer owners to get other tires or is it cheaper for them to keep the tires and get a new car? Does it make sense for them to replace tire at the place they bought them? or should Ford recall all Explorers and fix the problem and send the car back to owners in months?
Firestone designer didn't do their homework and excluded Explorer in their research. Every car companies have their own suspension system and Firestone is well aware of that fact. They will loose that market and it's their loss. I don't think there's soul out there that's gonna stay away from Explorer because it doesn't go with Firestone.
Do you even think car manufacturers have time and resource to deal with all these ridiculous brands and models of tires out there? They design a car for standard radial tires and that's it. If the tire manufact goes out of this spec, it's their problem. On the other hand, how many car makes do tire manufactures have to deal with? Only a handful. I hope this subject doesn't come back.
You asked for it.
--BrianC
