- Jul 12, 2002
Perhaps, but will you be any more willing to consider only diehrd cares?diehrd said:When they shorten the pipes and add a memory controller maybe diehrd will once again use an Intel
Anandtech said:As we found in our first article on Intel's 65nm chips, power consumption did indeed go down quite a bit; however, it's still not low enough to be better than AMD. It will take Conroe before Intel can offer a desktop processor with lower power consumption than AMD's 90nm Athlon 64 line.
diehrd said:And hey new people or people looking for new chips should see both sides of the coin . .
Super Nade said:Hiya Shawn, whats going on mate?
Anandtech say this: (http://anandtech.com/cpuchipsets/showdoc.aspx?i=2658)
Do you guys who have both (AMD and Intel chips), see this? Frankly, I don't know what to say about this, because my Opty 165 runs hot at 48C (2.7GHz, 1.5V) under load. So, where is everybody getting their Thermal comparision metric from?
Super Nade said:Look at the encoding and other multimedia benchmarks on the Anandtech review, not much of an improvement over the 1Mb brethren. So what purpose does adding extra cache actually serve? Maybe this would be useful if the pipelines were LONGER.
Super Nade said:So, have Intel moved away from the inefficient Netburst scheme?
batboy said:Looks like AMD is 6 months to a year behind the 65nm technology.
diehrd said:And yes someone started a thread showing there 65nm chip.And the sad part is it performs no better then the 90nm
diehrd said:..And i did not see this user get to 5 gigs on air matter of fact I think he posted 4.2 gigs stable
Which is where the 8oo series chips performed.And why I posted to point this out..The chips cost more perform on the same level..I like many seen a 5 gig Celey..I have also seen 5 plus gig 90nm intels..
Okagi said:Buying now would be like throwing your money down a hole. This next lot of 65nm has not evolved enough to make purchasing it a viable step. I say be sensable and wait for Conroe. Hopefully Intel will deliver the goods by then.
AMD clocks aren't purely archictecture-limited. Intel is still the silicon king, and will likely always maintain a clock speed advantage as a result, long pipeline or short.3DFlyer said:I hope when Intel shortens those pipes, they don't go overboard like AMD did, and limit the clocks.
larva said:AMD clocks aren't purely archictecture-limited. Intel is still the silicon king, and will likely always maintain a clock speed advantage as a result, long pipeline or short.
But really, this is quite enough of the AMD vs Intel rhetoric here. We have a general CPU section, and are inclined to allow even spirited debate of the relative merits in that section. This is indeed the Intel section, and I would prefer (well, let me re-phrase that, I insist upon) a lot less of that content here. If you want to explain why this Intel technology isn't compelling vs other Intel technologies, fine, but I'm drawing the AMD/Intel line at precisely this point in the sand.
Honestly, that's just the pot calling the kettle black.3DFlyer said:The General Section is really the AMD Fanboi section, and back about 2 months ago, I decided to avoid it like the plague. I am starting to believe this section is heading that way, and may have to avoid it too.
3DFlyer said:I hope when Intel shortens those pipes, they don't go overboard like AMD did, and limit the clocks. I doubt this will happen. From all the reports I have read, the clocks are going to be affected very little. It is not a given that short pipes mean lower clocks. It does in AMD land, but that's because of the lack of research and development, and the fact that they lose sight of what they are trying to accomplish. They are "Intel Driven" instead of "goal driven". If they worried less about what Intel does, and focused on what they are doing, they might be taken seriously. They still do not offer a complete solution, and I've seen no reports that they are even working on the problem.
Intel on the other hand is on a mission and they are succeeding.
Fact- The New Pressler delivers cooler running, clocks to 5 on air and 6 on phase, delivers what was advertised all along.
People who say this will be the exception instead of the rule are only fooling themselves. These are ES chips that are being tested, they are NOT refined retail models. The retail models will be better as they always are with Intel CPU's. The future steppings will continue to get even better than that...as they always do with Intel CPU's.
There may be a few that are blinded by AMD's ramblings on their website and all the BS they spew regularly, but I can assure you that it will be quickly quelled as these CPU's are hitting the market in a few days.
When Serious OCF members get ahold of these we will see clocks higher than ever before...just like we did with the 6xx series.
larva said:Honestly, that's just the pot calling the kettle black.
Their clocks are going to be affected. Woodcrest, which is based on Conroe and Merom, will launch at only 2.5-2.93 GHz. I doubt that any Conroes will launch much faster, if at all, than that.3DFlyer said:I hope when Intel shortens those pipes, they don't go overboard like AMD did, and limit the clocks. I doubt this will happen. From all the reports I have read, the clocks are going to be affected very little. It is not a given that short pipes mean lower clocks. It does in AMD land, but that's because of the lack of research and development, and the fact that they lose sight of what they are trying to accomplish. They are "Intel Driven" instead of "goal driven". If they worried less about what Intel does, and focused on what they are doing, they might be taken seriously. They still do not offer a complete solution, and I've seen no reports that they are even working on the problem.
I'm sure you've been through your share.3DFlyer said:Oh really?!? Then maybe it's time I move on to another forum.
To use an old saying, don't let the door hit ya where the good lord split ya.3DFlyer said:If that's the way people feel here, then i don't need it. I ain't. If you really belive that, then just see if the fanboi flames diapear once I am gone...which is right about now. So long.......
