- Mar 7, 2008
As posted previously I've had to manually replace fans on some GPUs before with case fans when they fail. One thing I never did was connect those fans to the GPU, and instead they currently get powered separately. I'd like to revisit reconnecting them to the GPU, but I never kept the failed fans as reference. Anyone know if the 4 pin fan headers on GPUs follow the same pattern as the mobo, or could it vary by manufacturer? They use a different physical connector, but its still 4 pins. So wondering if it would still be ground, 12V, rpm, pwm or could order be different?
