Hi,
I put together a custom built water cooled PC using a Nvidia geforce RTX 2080ti. In the first place i just had the normal confguration without the addition of water cooling. Everything worked fine, I had no problems. After I installed water cooling, the problems started.
When I boot the computer I have no problems. I can use the internet, watch videos, download games... When I am doing that, MSI afterburner is showing that the GPU is running at 29 degrees celsius. As soon as I launch a game (I launched Fortnite), the monitor stopped displaying and "the monitor is going to sleep" notificaton showed up. I finfthat very weird, because the fans, the RGB lights and the pump were still on. First, I thought that the monitor is the problem, so I connected a new monitor to the PC. I again turned on the PC and as before, everything worked ok. I thought the problem was fixed and it was the monitor that was the problem. I again launched Fortnite and it happened again.
I do not know what is causing my problem. I figured that the GPU suddenly stops working, because everything works fine, even the sound still works. I can not figure what the problem is. Because I have the GPU water block installed I can not even see if the GPU fans stop working.
Could the lack of thermal paste while installing the GPU block be the problem? Did I somehow damage the GPU while installing the water block?
