- Jun 24, 2014
- TX/CO
I'm planning on a build with a intel 4790k and two GTX 780's in SLI, with a custom water loop. Now that I'm looking into the different kinds of 780's, I'm concerned about selecting water blocks. I was just made aware that classified cards (which sound very intriguing) have a different PCB. I'd be leaning towards classified cards, but when I go looking for water blocks that will fit the classified PCBs, I can't find anything.
So my question is, if you choose to go with a custom loop, are you restricted to reference PCB cards, or is there another solution to water cooling a classified PCB?
Also, I suppose as a secondary question, would a single loop be sufficient for cooling both the OCed CPU and GPUs given enough radiators? I had my eye on the HAF X case, which I believe has room for a 360 rad on the top.
Any insight would be much appreciated.
