- Dec 1, 2007
- Near Toronto Canada
I've always read to buy as much GPU as you can afford to get, because for the past 5 years (10 years?) it seems like the GPU is the far and away the greatest determining factor in gaming benchmarks. I've "upgraded" in the past and ended up w/no noticeable difference in performance (when I went from a 9800 XT 256MiB to an x850XT 256MiB for example).
How many games did you make this comparison with? One?
Sorry but the same question applied.
A more powerful GPU will give you more performance. You might not have checked it out with enough games. You definitely should buy the best single GPU you can afford. SLI is, in my opinion, only if you're using multi monitors, or, say you buy one GPU now and another in 2 (when they're bargain bin parts) years to extend the lifespan of your system.
