Received my HAF X case last night and after I got it all together I only had 2 problems.
First one isn't nothing major, just my 280mm radiator wasn't wide enough to use all the screws up top. But some zip ties fixed that for now.
Secondly, my top 200mm fan won't spin on startup. I have to snap the front panel off and spin it with my finger a little bit. Then it will start spinning normal.
I took a screwdriver and pried down on the fan a little bit. It started spinning on power up 3 out of 3 times. So I shut the power off and went to bed. This morning I powered it on and it spun just a little bit and stopped. So I had to spin it with my finger to start it.
Was it put together a little too tight? Just been worrying and bothering me since last night since my case doesn't function fully.
