K
Kall5545
Guest
Hello
ATI Radeon Sapphire HD 3650 AGP 512MB DDR2/3(2008).
1.) If I CNC a custom copper heat sink will I need spacers between GPU and heat sink ? Or can I just screw it in ? Why 3rd party\aftermarket coolers provide spacers ? Are they needed to adjust right pressure and without them GPU breaks when heat sink is screwed in ?
2.) What thermal conductivity pads Chinese=1.4 W/mK, Arctic-AC=6.0 W/mK or Alphacool=11W/mk ? What size is ok 0.5, 1, 1.5mm ?
3.) I read a review that has one of those PCI-E to AGP bridges. Here is a reference to the text and the reviewer thinks it really needs a heat sink... Do I use a 1 pc tiny heat sink 10x10mm for the small bridge chip or how do people cool these ?
Review that talks about the bridge chip:
https://www.bjorn3d.com/2009/10/sapphire-hd-4650-agp/
"Once I turned the card over I was terrified to see this. No heat sink what so ever… I don’t know what was going through the Sapphire engineers, but this chip really needs a heat sink. I would suggest rigging something together otherwise the card will probably not last as long as it should."
