- Jan 19, 2008
- Folding the PWN, Salem Oregon
- Thread Starter
- #21
did that, skips it and goes to loading up something about grub 1.5
alright, im fixed up and running but now im having trouble getting linux video drivers for my 7600gs.
both of you obviously missed the post that jamesxp made, ive already done it through hardware manager AND IT DIDNT WORK!
you also dont grasp the concept that i dont know how to use linux, i dont know how to install/un-install, whatever envy is, anything! you have to explain it to me as if ive never used linux before because i havent!
sudo apt-get install envy-ng
sudo apt-get install envyng-core envyng-gtk
sudo apt-get install linux-restricted-modules-server
You can also install this package from Synaptic Package Manager (which I did.)
Go to System > Administration > Restricted Drivers Manager and turn on the driver.
Reboot
Some users may receive an error screen: "The software source for the packsge nvidia-glx-new is not enabled." This can be overcome by going to
System > Administration > Software Sources
and ticking all the boxes under the heading "Downloadable from the Internet", click close and then allow Ubuntu to reload the package lists. The NVidia drivers can then be enabled using the method above.
You can optionally prevent showing NVidia logo on startup by:
Code:sudo nvidia-xconfig --no-logo
