Thank you in advance for the help that you might give me.
Just 25 minutes ago I was playing Shadow Of mordor, when suddenly the game pauses, freezes and BSOD with a buzzing sound.
Dismissing it, I restarted my pc and restarted the game.
( once i started the game I checked my cpu temp which sat at 32 Celsius under load.)
Then after 15 minutes the same scenario happened.
So I restarted, went into the bios and loaded the optimized defaults.
I selected the restore prompt, but then all my pc gives me is just a black screen.
Which leads me to believe that my 290x is borked?
Also take note that I was running it at stock clocks.
What do I do?
Thanks.
What do I do?
Thanks.
