man its tempting. Im sure if you guys helped me with parts I would end up doing that. I already bought the ram and the power supply that was more mentioned in 2nd post. Eh screw it ill put $1200 In. Is monitor included in budget?
Good thing I checked this post today cause tommorow I was getting 24 inch 144 hz asus monitor lol and the graphics card mentioned in the 2nd post of thread. So sure id appreciate help as if it was 1200 budget.
What is the difference of quad core than the latter? Is it just clearly alot better?
I have to say I get more and more excited for every part i buy or about to buy. This comp is going to be a god tier upgrade compared to what I have now!
The Intel quad cores are more powerful than the AMD 6 cores because the cores on the Intel side are stronger. AMD uses "modules" which are 2 cores each and those cores share resources. Intel cores are more "independant".
If you want to do $1200 with a monitor included in the budget you have a couple of different options:
1) If you already have an OS (Windows 7 or later) that's not installed anywhere else you can use it for this build and save $100. In that case I suggest:
i5 4670K
ASUS Z87-A
your existing RAM
your existing power supply
Western Digital Blue 1TB
your choice of cheapo DVD+RW drive
ATI R9 280X GPU
Corsair 200R case
^This is the build I would do personally with $1000 budget for parts.
-OR- you can get the CPU and MOBO from the first build which, although inferior, will still give decent performance, and you can put another $100 towards and even better GPU, or use it to buy an SSD now instead of later.
That leaves about $230 for a monitor, which will buy you a half decent model.
If you need to buy an OS (buy windows 8.1), you will need to drop the GPU to a lower model. In this case I suggest a GTX 760 2GB. They start at $235 (vs $299 for an R9280X). This frees up $65. You take another $35 from the monitor (leaving $165 for the monitor) and you have $100 for Windows 8.
Don't buy an SSD right (for the Intel build) now as it'll further eat into your CPU and GPU budgets. Buy one later when you have $100-200 spare. Samsung 840 EVO is most recommended on this forum because it is cheap and has decent performance.
This build has an overclockable CPU and motherboard so when you get yet another $80 or so you can get a top tier air cooler like an NHD14 or NHD15 and overclock the snot out of your CPU.
