- Thread Starter
- #41
Seriously you don't think I know that?Why did you order both a Bluray writer and a DVD writer? A Bluray writer will burn DVDs and CDs too.
I put 2 drives cause that's what they asked for. I am guessing for 1:1 copies idk.
Why would you go with a the 860 EVO instead of the NVME? There would be a loss of performance in doing so. Is this a cost cutting measure?
And why would you go with the 9900k instead of the 9900KF? Are you saying you would drop the video card in favor of using the 9900k IGP? If you are keeping the video card that doesn't make sense.
�� Seriously you don't think I know that?
Yeah I know cause I had a hard time finding a good case that still had 5.25" external slots. I've worked with this Thermaltake Core V71 before. Although it's a full tower, the airflow with the 200mm fans is great and cable managment is a breeze.So this build is not for yourself. I don't think you mentioned that in the beginning. Installing two optical drives just struck me as odd being as how optical media is slowly on the way out. A lot of new factory built computers don't even have them anymore and 5.25" slots are becoming uncommon in aftermarket towers.
I mentioned earlier I got the Scythe Fuma 2 120mm instead of the CM Hyper 212 EVO. I am reading up on some stuff I can disable in Bios to improve temps.I hate to break this to you but a CM Hyper 212 Evo is not going to cut it when stress testing a 9900k with newer releases of Prime95. It would probably be adequate for most real life computing tasks but, having said that, video editing is pretty demanding I think. Did you have the AVX 512 box checked or unchecked in Prime95?
There isn't much.. it's voltage you adjust.I am reading up on some stuff I can disable in Bios to improve temps.
Thanks and this is not my rig, building it for a friend. I am however now tempted to build myself a new one.There isn't much.. it's voltage you adjust.
(update your signature, btw)
Thanks that's the video that convinced me to get this cooler over the Hyper 212 and yeah I understand water cooling would be better.This video shows temp results from cooling a 9900k with the Sycthe Fuma 2.
