Here's the scenario: I built a system in August, 2010 and after a while, my PSU started making squealing noises while my system was under load. The intensity of the noise would vary depending on the intensity of the load (obviously). I first noticed it when I was running a full system analysis in Passmark Performance Test and it got to the 3D graphics part of the test. The PSU started squealing very loudly, with a high pitch. I next noticed the noise when playing Crysis (although the noise started even during the main menu of the game, before any real gameplay had started). After a while the noise seemed to get worse, and now I can even hear a slight hum while scrolling up and down on web pages (especially ones with a lot of pictures) and while watching videos on Youtube and what not.
Anyway, the PSU is a TR2 750W (http://www.microcenter.com/single_product_results.phtml?product_id=0323928). I have read several customer reviews, and many people have had the same problem with this PSU.
And so, I am looking to get a new PSU before this one dies and possibly destroys my entire system. My system is:
CPU: i7 930 @ 4.2GHz, 1.288VCore - http://www.newegg.com/Product/Product.aspx?Item=N82E16819115225
Memory: 3x2GB Corsair XMS3 DDR3 1600 - http://www.newegg.com/Product/Product.aspx?Item=N82E16820145286
Motherboard: ASUS P6X58D-E - http://www.newegg.com/Product/Product.aspx?Item=N82E16813131641
Graphics Card: Palit GTX 460 Sonic Platinum (factory overclocked) - http://www.microcenter.com/single_product_results.phtml?product_id=0341978
HDD: Western Digital Caviar Black 6Gb/s 1TB - http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
SSD: Intel X25-M 80GB - http://www.newegg.com/Product/Product.aspx?Item=N82E16820167023
CPU Cooler: Titan Fenrir - http://www.microcenter.com/single_product_results.phtml?product_id=0334422
PSU: (see above)
So, basically what I am hoping to get from you guys is an estimation of what PSU specs I need (wattage, amperage on each rail, etc.), and some suggestions of some good PSUs that will meet these specs. I tried the PSU calculator that was stickied on this forum, and it said I need 654W. I wasn't sure if I should trust that, because it seems like I would need more than that with my overclocked CPU and GPU.
Also, please keep in mind that I would like to have room to upgrade my system without having to also upgrade my PSU in the future. My most immediate plan is to get another GTX 460, identical to the one that I have, or perhaps an HD 5970 or GTX 580.
Anyway, with all that in mind, I would appreciate it if you guys could help me decide what specs I will need in a PSU, and which PSU is most worth buying.
PSU: (see above)
