- Jan 24, 2006
- South Dakota
well res's work like this
in theory the bigger the res the longer it takes for the system temp to rise
extreme example:
if lake hurion was your res it would take forever to get the temps to rise
in a loop this small it doesnt make much of a difference because no one is really going to have a res big enough inside the case to make that much difference
as for the coolent... most people make their own stuff.. the most common is 75% distilled water and 25% antifreeze... also getting some biocide, non-alcoholic iodine or algecide keeps stuff from grown in your loop (you dont need much maybe 3 mls?)
for just the cpu IMHO the BIX2 is over kill... you could probably cool it with just a BIX or even a BIP. (i just happen to be selling both lol but thats another thread)
as per the fans
here is something that I didnt know until a couple of months in each rad needs a different type of fan
the BIX type rads are made for performance and visually look almost 2 X as thick as a bip... thus they need higher CFM fans to be effect where as a bip cools just find and can do it with less noise, and less powerful fans
EDIT: Clamps are kinda a personal thing some people use these
and some people use these
and still others use zip ties
as per fittings what exactly do you mean?
extreme example:
as per the fans
