Hey guys.
A few days ago my mobo gave in (MSI 970A - G43) and the system wouldnt boot (fans +lights start for less then a sec.) so i changed the mobo to a MSI 970 Gaming and the Pc gives no Vid output. (PC specs below.)
I have tried changing the RAM, using one at a time, ect.
Tried changing the CPU. (same socket type)
Tried changing videocard, twice.
tried changing PSU,
Disconected all HDD/SSD
tried resetting CMOS.
Need a resolution ASAP as went wrong on my last minute checks for a LAN event in 12hrs (2hr drive means needs to be good in 10hrs so i need a solution in 8hrs.
Specs,
Mobo - MSI 970 GAMING
CPU - AMD FX 8320E black edition
GPU - Saphire R9 270oc 4Gb
Drives - 1 Kingston 240gb SSD, 1 HyperX 240gb SSD, 1 WD 500gb 5400rpm hdd.
RAM - 2 4gb vengance 1600mhz, 2 4gb hyperx 1600mhz
CD - cheap samsung x24 rewriter
Case - Zalman Z12 plus.
tried changing PSU,
Specs,
