- Dec 19, 2001
- Wausau, Wisconsin
Okay,
I have an AMD Phenom II 955 @ 3.21 Ghz in a Gigabyte MA790XT-UD4P and am trying to run a Raid 0 array with 2 Seagate 1.5 TB Barracudas. Stripe size is 16k because someone told me you should only set it at that if your using windows due to a 4:1 ratio between that and the 4kb cluster size windows has...anyways my problem doesn't seem to be with any of that but during my windows installation when it asks if I want to create a partition or format the one I have both drives are only showing up as one as they should be at 2861563 MB, but when I try to hit enter to just format it it doesn't do anything...Am I supposed to create the partition at half the size of that and then format that one cuz that's what I did instead for some reason it just won't let me format the raw 2861563 MB space unless I reduce the size alot. Any help is much appreciated cuz it takes a long *** time to format these friggen things. Oh and I loaded the 64 drivers for my gigabyte raid array with Nlite directly into my OS since I don't have a floppy controller on my board.
