Help Who makes Gigabytes Xtreme Waterforce waterblocks?
Hogbert_1999
I have hit a snag on my first loop....
I have this card but it is just a fraction too tall so i need to know if i can use an L bridge to make it shorter and fit int he case??
Questions:
1Who is making the waterblocks for Gigabyte Xtreme waterforce series??
https://www.gigabyte.com/Graphics-Card/GV-N208TAORUSX-WB-11GC#kf
2. Will any of these fit?
https://shop.bitspower.com/index.php?route=product/product&path=67_102_201&product_id=3437
Bykski_VGA_XS18_QSQUALL_Change_Direction_L_type_GPU_Block_Bridge_Acrylic_Bridge_For_Bykski_s_G...jpg
https://www.aliexpress.com/item/Byk...-Acrylic-Bridge-For-Bykski-s/32946406283.html
Barrow_BSDQT_PA_Multifunctional_Acrylic_Change_Direction_L_type_GPU_Block_Bridge_For_Barrow_s_...jpg
http://www.formulamod.com/barrow-bs...r-barrows-gpu-water-block-refit-p1798862.html
My ultimate goal is to achieve this outcome:
I have the GPU card already so I can measure from it I just dont have access to any of the measurements for the aftermarket low profile l brackets for the Inlet and Outlets.
All help and ideas most welcome.....
I really want to get it in with the side cover on and it is proud by like 1.5mm GGGRRR
I am not sure, but would bet it is EK as they had a relationship to make motherboard blocks a few years back
You should call them to confirm
This card has a custom PCB, not sure any reference block will fit ?
Yes to 011D but have too and bottom rad no vert option.
I have dropped a post in the gigabyte forum and sent them a support q hopefully they will help me out a bit
This guy made it work with a Black Ice GTS in the bottom, using a kit from cooler master. Although there wasn't really room for his fans on the bottom, so he had to add feet to the case. I can't tell if he's having some issues with sag there due to the mounting, or if his pictures are just at an angle. Either way this could be overcome with some creativity.
Yeah I saw that and will look into it however I am wanting to keep the fans inside the case. I am looking for the l type adapter to fit or I may need to shave it down a mm or 2
I hate to say it, but have you considered returning the gigabyte card and using a shorter one? There is a list of compatible GPU/block combinations on Lian Li's website.
