- Dec 8, 2008
Hey guys,
I am in the process of re-teaching myself java, and as a way to solidify stacks in my brain (never really understood them till yesterday pretty much... kicked myself after I realized how nice and simple they are) I am creating a calculator. At the moment, it can function as a standard (12 + 6) or post script (12 6 +) calculator, and can handle many, many operands and operators.
The issue I'm currently working with is a method of determining/enforcing the order of operations. (Please Excuse My Dear Aunt Sallie) and all that. Eventually I'm going to work on turning this into a simple GUI calculator.
The application, as it stands, supports addition, subtraction, multiplication and division. I plan to add a method for exponents as well.
Here's my code:
Here's my code:
Code:
/**@Author: J. Carter
*@Date: 6/25/09
*This started as an RPN calculator ( 12 5 + is equal to 12 + 5), however it can handle both standard
*(although not in the proper order) and RPN notations. Error checking built in to make sure the user
*enters valid input, will notify of invalid input and reprompt.
import java.util.*;
public class rpnCalc
public static void main(String[] Args)
String str;
String[] tokens;
double result;
Stack<Double> operands = new Stack();
Stack<String> operators = new Stack();
Scanner kb = new Scanner(System.in);
//initialize varables
str = "";
result = 0;
System.out.print("Enter a simple expression,\nSeparate pieces with a space, example: 12 + 96, or 12 96 + \nPress q to exit\n");
System.out.println("All expressions are evaluated from RIGHT to LEFT.");
while(!str.equals("q"))
str = kb.nextLine();
tokens = str.split("\\s+");
fillStacks(operands,operators,tokens);
result = calculate(operands,operators);
System.out.println(result + "\nAnother Expression? (q to quit)");
} // end while
System.out.println("Thanks! Bye now!");
}//end main
/** Methods for Addition, Subtraction, Multiplication and Division */
private static double add(Stack<Double> stk)
double op2 = stk.pop();
double op1 = stk.pop();
double result = op1 + op2;
stk.push(result);
return result;
}// end add
private static double subtract(Stack<Double> stk)
double result = op1 - op2;
stk.push(result);
return result;
}// end subtract
private static double divide(Stack<Double> stk)
double result = op1 / op2;
stk.push(result);
return result;
}//end divide
private static double multiply(Stack<Double> stk)
double result = op1 * op2;
stk.push(result);
return result;
}//end multiply
/**Method for error checking user input. If parseInt fails, this method is invoked, and determines whether input is invalid,
or an operator.*/
public static boolean isOperator(String str)
boolean tf;
if(str.equals("+") || str.equals("-") || str.equals("/") || str.equals("*"))
tf = true;
else if(str.equals("q") || str.equals("Q"))
tf = false;
else
tf = false;
System.out.println("Invalid input. Please try again.");
return tf;
}//end isOperator
/**Methods for filling stacks and evaluating expressions.*/
private static void fillStacks(Stack<Double> stkd, Stack<String> stks,String[] str)
boolean isOp;
for(int i = 0; i < str.length; i++)
try
stkd.push(Double.parseDouble(str[i]));
}//end try
catch (NumberFormatException e)
isOp = isOperator(str[i]);
if(isOp == true)
stks.push(str[i]);
}//end catch
}//end for
}//end fillStacks
/**perform calculations based on operators, loop until operator stack is empty*/
private static double calculate(Stack<Double> stkd, Stack<String> stks)
double result = 0;
String str = "";
while(!stks.empty())
str = stks.pop();
if(str.equals("+"))
result = add(stkd);
else if(str.equals("-"))
result = subtract(stkd);
else if(str.equals("/"))
result = divide(stkd);
else if(str.equals("*"))
result = multiply(stkd);
}//end while
return result;
}end calculate
}//end rpnCalc
