- Aug 30, 2002
- Southern USA
I'm trying to use a Samsung SyncMaster 216BW with an old rig to play WOW on. I was wondering if there is a way to increase my FPS from what it is at now.
216BW Specs:
-Response time of 5ms,
-DC 3000:1 contrast ratio,
-0.276mm pixel pitch,
-1680 x 1050 maximum resolution,
-Scanning frequency of 30-81 kHz horizontal and 56-75 Hz vertical, and horizontal/vertical viewing
Oldskool Rig:
Athlon Mobile Barton 2500+, currently running at 1.8Ghz (9x200FSB) until I get a better cooling solution, as my current temps are 59C under full load with a case temp of 36C and a room temp of 24.8C. This is at a Vcore of only 1.57. Using a Volcano 6Cu+ heatsink with Artic Silver.
Mobo: Abit NF7S v1.2
Vid Card: HD3850 AGP (Benchmark score of 17671 using 3D mark)
Memory: OCZ 2x1GB running in dual with stepping at 2.5-3-2-5
Prime95 stable, no worries.
Windows Display Resolution currently set at 768x1024 @ 75 hertz. Montior can only do 1680 x 1050 60Hz
HD3850 Driver settings using it's bundled Catalyst Control software:
Anti-Aliasing:Use Application Settings
Anisotropic filtering: Use Application Settings
Catalysis AI: disabled
V-Sync: Disabled/OFF
MipMap detail level: Highest
Adaptive Anti-Aliasing: OFF
WOW settings:
Display: 1680X1050
60hz refresh rate
multisampling: 1x
V sync: OFF
Effects:
Everything turned on and maxed out with the exception of shadow quality, which I have set at one notch below max setting.
Walking around in fields, I get in-between 65-80 FPS.
With the WOW settings at:
Display: 768x1024
75hz refresh rate
multisampling: 1x
V sync: OFF
I still get in-between 65-80 FPS.
With the WOW settings at 768x1024@75hz or 1680X1050@60hz with all effects turned all the way down, I get 100-120FPS.
It appears as if the resolution plays no role in FPS.
Can I expect to get better FPS the CPU is at 2.2-2.GHz as opposed to 1.8GHz or is that not going to help much? I'm pretty happy with the FPS, but I'm just wondering if anyone has any more suggestions to improve it further.
216BW Specs:
Oldskool Rig:
WOW settings:
Display: 1680X1050
60hz refresh rate
multisampling: 1x
V sync: OFF
Effects:
Display: 768x1024
75hz refresh rate
multisampling: 1x
V sync: OFF
