After a bit of googleing it looks like the nf a14 3000rpm is the choice replacement . I dont care about noise, is there something that will move more air?
I found one site that said putting one GT ap-30 120mm (116cfm) in the center got the best result. I'm not seeing anywhere it's for sale though
I did a review of modern fans on the NF-D14 here:
https://www.overclockers.com/noctua-nh-d14-redux-modern-fans-on-an-old-heatsink/, but I did not have an NF-A14 iPPC 3000. A user on another forum did, however, and got another 4c cooling from the D14.
The GT is a 120mm fan that specializes in high static pressure.
The NF-A14 is a 140mm fan optimized for high airflow at reasonably elevated static pressure. Its biggest competitor would be the Thermalright TY-143, a 140mm PWM fan that has a nominal speed of 300-2500rpm. If you can get the Noctua fan, get the NF-A14 3000 iPPC PWM. It has a speed of 450-3000rpm.
In any case, Noctua still makes the D14 even though it is EOL. People still buy it, so they make it. I prefer it to the D15 that replaced it. Both are still better heatsinks than anyone else makes.
As for modern fans on a D14 or D15, the middle fan should be 140mm. The D14 ships with a 120mm front fan, and in private testing I found the NF-A12x25 holds up well in front, finishing about as well as an NH-U14S. That result was left off the chart in the review, probably from forgetfulness. But really, if your case is big enough to handle RAM+140mm fan, go for the larger fan in front.
As for Noctua, as Blaylock noted, they make their heatsinks to be quiet, like an owl -- hence the name (Noctua is an owl) and the emblem.
