hi,
newbie here, trying to get the most out of my system, so obviously trying to o/c.
the highest FSB i am able to get is 145Mhz, with a multiplier of 11, giving me 1595Mhz. whenever i try to go higher with the FSB, the system wont start(it will get past the boot/post screen, but i will get an error when the windows screen appears, and it wont load windows)
what? lower the multiplier you said, and then increase the FSB? tried that, still wont work, i had it at 146mhz FSB and multiplier at 5, still wont boot, whats wrong?
athlon 1.4ghz
shuttle ak31 v3
256mb kingston value ram (ddr pc2100)
cooler master HSF ($5 from newegg.com, keeps my cpu under 50C with full load non o/ced, at 1595Mhz, cpu goes to 55C under load)
i really dont want to do any pencil trick things, cause i know that i am a clutz and i might mess something up, is there something specail that i should do in the bios?
also, i got a new cooler master HSF from a friend(HHC-001 or something), its a copper HS, 7000RPM fan, has something called a heat pipe in it, i installed it replacing my old $5 HSF, and its worse! temps got upto 60C non o/ced, so i took it out. i am using arctic silver compound, and i noticed that it was getting good contact when i took it off, any ideas on this? i sanded the bottom smooth with 1000 grit sand paper, if all else fails, anyone want to buy a slightly used HSF?
athlon 1.4ghz
shuttle ak31 v3
