- May 28, 2004
Ok i just installed h20 to my computer and the first CPU i used was an athlon 3300 64bit @ 2.75ghz using 1.8v. (only 256k L2 cache 64bit cpu, found in HP/Compaq computers), and it ran at 25c idle 33c load. Now i have just sold that and reinstalled my 2800 64bit cpu and it idles at 38c and load at about 46c @2.5ghz using 1.55v. That seems like a pretty big jump considering the only differance between the two was that one has 256k cache and the other has 512k.
I have remounted my cpu block twice, and added the same amount of AS5 i used for the 3300. I just don't understand how the extra L2 cache pumped up my temps 10-15c, when i am using .25 less volts to boot
My h20 setup is an RBX all copper block, 1/2" tubing, Eheim 1250 pump.
Also i have no kinks in my system either, plus its 99.99% free of air bubbles.
