I found this while browsing the net, apparently his water pump failed and it was a little while before he noticed.....
I don't have the link you were looking at but the interesting and positive aspect of the whole situation is that apparently the cpu throttled itself and there was no fire or real damage. I mean HWMonitor and windows did not even crash or she should have had nothing to capture is my guess.
What appears to have happened is why I don't go OCD over temps. If I were in that great a need to control temps, I should be in the HVAC line of work. I have poured tons of volts thru cpus with good coolers (not these cheapies) and never had a cpu fail. Period.
From only what you show, the outcome seems very positive and re-assuring.
so how could a 965 get that hot without throttling or shutting off, I've ran prime95 with no cooling and 65c was the highest I've ever seen my chip go without either bsod or throttling, even with the thermal crap in my bios disabled you can't turn off the chips thermal protection.
I don't understand. None of the voltages went down as it should in a thermal throttling.
Look at my post #2 above and see where I put the strike-thru. Struck thru the misleading word 'throttling'.
After a good bit of g00gling, I never saw where AMD does throttling for high temps. It should instead 'shut-down' the system.
