- Dec 28, 2005
- In your mirror
Picture this:
A 40mm square block of solid copper wrapped with (5) 245w pelts on each of the 5 sides. The open side machined down to fit the IHS.
Yes, terribly inefficient, over 1000w of power @ almost 100A and will require a lot of water cooling capacity, but only used as a benching device running a few hours/day. A 250w load spread out across 5 TECs should be 50w/TEC, putting delta T around 52c. If I could keep the backside @ 30c, should produce a -22c load temp @ 250w.
Will be looking for other TECs that can pull down > 60c delta T. I've got the power supplies, copper and machine shop to easily build this, but will it work?. Anyone done anything like this?
