- Jun 29, 2005
- Over Here!
Since I've finally got all the pc parts to complete the equipment side of my build; my next step is to do some modding. Starting with the removal of the mesh on the front intake, as well as the top mesh where I have two 140mm exhaust fans, and rear exhaust mesh; needless to say, a lot of cutting.
Part two of my case mod, is to etch a logo into plexiglass/acrylic/lexan etc... so I'm really looking for a tool that can accomplish both of these tasks.
After searching the forums and Google for an hour, I believe a rotary tool (dremel) is what I need, but I'm just not sure which will serve me the best...
I believe this Rotary Tool is what is generally suggested, along with some reinforced cutting discs. Will I also be able to use an attachment for etching plexi/acrylic/lexan? Any advice on which specifically to get? Should I look for a rotary tool w/ a 100 piece kit or pick up the rotary tool and get what discs I need separately?
I've also watched a ton of video's about the Nibbler Tool, but I just don't think it will be the easiest way to remove mesh; at the least, I think I'd need to get a dremel tool to at least get the cut started...
I have Walmart, Home Depot, Lowe's etc near by, so I'd probably go pick one up from there... I just want to make sure I'm getting the appropriate tools for the job.
As always, thanks OCF for any help or a kick in the right direction! I know this has been covered before, and to help those in the future, I'm going to turn this into a build log, to pass along any experience and information I may gain from this project.
PS - The 650D in my sig is the case I'll be modding...
