I made a post in the cpu section asking about the processor and got some quick help that informed of the flawes i had in the computer i was going to build so here is a revamped list that i belive should work well together. I didnt go with the 550(?) fortune because im already that close to my budget and backing off on the board opened up the room for this one check and see if it looks good.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=541440&Sku=D15-1002
http://www.newegg.com/app/viewproductdesc.asp?description=13-127-164&DEPA=0
http://www.newegg.com/app/SearchProductResult.asp?Description=19-116-175&DEPA=
http://www.newegg.com/app/ViewProductDesc.asp?description=20-231-004&depa=1
http://www.newegg.com/app/viewProductDesc.asp?description=22-144-170&depa=0
http://www.newegg.com/app/viewProductDesc.asp?description=27-190-008&depa=0
http://heatsinkfactory.com/cgi-bin/HFAstore.pl?user_action=detail&catalogno=HS-008
http://www.newegg.com/app/viewproductdesc.asp?description=14-127-155&DEPA=1
http://www.newegg.com/app/ViewProductDesc.asp?description=35-150-007&depa=0
http://www.newegg.com/app/viewproductdesc.asp?description=17-104-962&DEPA=0
btw as i stated in my other post i will be ordering the 11th so really would love some quick help.
