- Jan 22, 2011
- Berlin, Germany
- Thread Starter
- #21
You've already gotten all the info you could need for getting you started on your DICE adventures.
I can only reiterate what has already been said... Insulation, Insulation, Insulation. It is all about the insulation; as long as you protect the board from condensation you will be ok.
As far as killing stuff while on DICE...
I killed a Rampage Extreme within five minutes of my first time using it... It wasn't because of the DICE, or bad insulation... I removed the POT to replace the CPU and in the two minutes that the socket was exposed; condensation formed and when I fired her back up she took an early departure from the world of the living. People that were there for that night (over livestream) will remember it as the night when everything that might have gone wrong for me; did go wrong... Came close to destroying my pot and killed my REX... That night almost turned me off of benching for good, but in the end the bug remained and I am still here, freezing stuff.
Safe to say I have been much more careful after that debacle and haven't killed anything else... I do miss my REX though.
Ouch, that does not sound like I want to go through the same learning process
So you need to insulate the actual socket pins? Doesn't there have to be direct contact?
