- Jan 12, 2012
- Thread Starter
- #21
That's the same one I foundIs there a different link for chipset drivers or is this it:
https://downloadcenter.intel.com/De...rsion=Windows XP Professional*&DownloadType=
i wouldnt worry about video drivers if just running 2D benches on XP. (unless going old 3D benches)
i usually go install xp, msconfig and disable all processes, enable themes and plugnplay, tweak what you know, then bench. No lan, audio, security, nothing!
looking at hwbot submissions theres the majority using XP on Z87, so it must be doable.
i usually change bios to IDE for my XP HDD with many partitons, secondary HDD for WIN7 (which i sewitch back to AHCI)
USB drive to HDD format in bios, otherwise XP wont install properly.
It doesn't matter what Nvidia driver I use, I need to get microsoft .net framework 4 installed correctly in order to install the drivers for the Gpu.what nvidia drivers you trying to use?
I have the cold loop setup in my office with the rad hanging out the window so I can bench and use the AMD setup at the same time. Whats really nice is the CHV and the ROG connect.2 PCs when benching... gotta keep a lappy around for things like this.
i usually change bios to IDE for my XP HDD.
I was thinking the same, does anyone know if I need to install the previous versions on .net framework in order to get .net framework 4 to install properly?Does .net 4 include all the older stuff. I thought they were seperate
