Just curious as to why you want to remove the Change button?
Tried this?
http://www.askvg.com/how-to-enable-...-kind-of-file-option-in-open-with-dialog-box/
Found, amongst others, with this search string.
https://www.google.co.uk/search?hl=...q="disable"+change+of+default+program+windows
Is there a way to undo all file associations a specific user has made/changed?
For someone with so many stars your google-fu is disappointing.
http://www.sevenforums.com/tutorials/19449-default-file-type-associations-restore.html
Those are individual restorations so he would have to know which ones the user changed.
If they are set up correctly, limited user should not be able to perform Admin changes that affect the entire system.
The OP is not going to find out all the changed file associations that have been made.
Reset the all the associations back to default decreases the chances of "This file cannot be opened by xxx"
He can do this by downloading the reg file supplied in the link I provided in my previous post.
He still sounds butthurt.
