- Dec 14, 2010
I have a serious issue here.
I have a PC that came to me from a friend with Windows 8.1 on it and I've been working on this issue for nearly four days now to no avail. The friend asked me if I could possibly fix their PC.
When it first came to me it was infected by malware and spyware, and I was able to remove all of that. However, when I went to check for updates I discovered that there were a dozen or so available, and so I chose to install them. But Windows Update quickly stops the update process and comes back with error code 80073712. Upon further research I discovered that it hasn't been able to successfully install any updates since March of 2015.
Running SFC /scannow returns saying there is file system corruption, but it is unable to fix it.
After researching that a bit I came to the conclusion that I was supposed to run something called DISM.exe from an Administrator-level of access at the command line to fix this issue. That however quickly returned another error message, Error: 14098, The component store has been corrupted. https://support.microsoft.com/en-us/kb/957310
https://social.technet.microsoft.co...alth-returns-error-14098?forum=w8itprogeneral
https://technet.microsoft.com/en-us/library/hh824869.aspx
Running CHKDSK.exe returns and also says there is file system corruption. But when I attempt to run CHKDSK /R or /F the scan stops at 10% and never proceeds beyond that point (I left it running for two hours and it never got any further).
I read somewhere that I could use an MS 8.1 installation disk to help with repairs, but setting the disk drive as the source for the DISM seems to have no effect. Like it can't even see that the disk is in there, or it just can't locate the proper files to repair the installation.
Does ANYONE have any suggestions for how to repair this system image? I'm at my whit's end here and frankly I'm about out of ideas on how to deal with this issue. I'm afraid I'm going to have to reload this POS, which won't exactly be easy since it came with Windows 8 and I don't currently have an installation disk for 8 (that, and I don't know if I can back up the files from this drive to a Windows 7 machine (don't they have different filesystems?)). Do have an installation disk for 8.1, but I don't know if it can be used with a key for Windows 8 when going for a fresh install.
I HATE Windows 8 and 8.1 SO much right now.
