Interesting.
As far as I understand things, you might only need 1-3 of these to perform a logic function that would typically be done by 6 or 8 transistors. I think they perform in some ways that are logically similar to electromechanical devices such as relays, which is what the earlier computers were built with, before they used vacuum tubes or transistors. The only drawbacks to electromechanical logic elements I think were speed and reliability. I believe this is similar to the technology that has been talked about as "molecular switching" At the simplest level I think each molecule acts just as a on/off 1/0 switch. You can see how this would apply to memory technology quite readily, that's all you need, a switch that can be set.
These also look like they will be very low power low heat devices. The density is amazing. If this were added to conventional CPU manufacture, then for an extra die area of only 2 square millimeters, one could get a memory array of something of the order of 80 terabytes
If this switching is static and long term, we could be saying goodbye to hard disks in 10 years. Although if an Xray laser diode were available it's possible that we could see densities within an order of magnitude, using similar molecular switching techniques, using a cheaper unorganised molecular deposition onto the disk, which would then be scanned and indexed optomechanically.
Actually thinking about it, it's conceivable that using an opto-molecular switching technology of even a quarter the density, one could make a 36 petabyte HDD (That's gotta be at least all the movies ever made all in HDTV format and MPAA think they've got probs now!
) with a miniaturised non-solid state laser, in the same form factor as a modern 3.5inch drive. And if the drive manufacturers are smart, they're doing that now and will have it out in 5 years
(I'm thinking the data surface could be a 1cm x 6cm "roller" or drum at one end of the drive, and the laser could take up most of the rest of it, with opto-electrical scanning of the drum by the beam, either through liquid crystals that bend light or solid crystals that deform under electrical stress. ... )
hmmm, I'm checking my math again and again because that seems a so amazingly large amount of storage, but I keep getting the same figures for a 3nm device size. .. ... ....
Road Warrior
