- Apr 3, 2015
- Planet Earth
- Thread Starter
- #21
Yikes! That block is EK, the res FrozenQ and the pump some PPC Swifttech job. No Koolance components, only fittings and coolantBlaylock said:..I would definitely contact koolance to find out their recommendation...
Not sure when/if I am going that route yet... (You see Koolance is #1 rated coolant on PPC...)
Har, I can't blame it all on the coolant, but something happened,,,
The GPU loop is all koolance components, minus the EVGA HydroCoppers, which I guess I need to open up as well.
Pics are pre-washing/anything. But I did blow on it and pat it dry quite a bit, and gunk came out of the fins in the process.
My plan is to gently wash everything with soap and water, soft-bristle tooth brush and then see what it looks like.
Here is an interesting blurb in my newest and first Watercool Heatkiller product.
Gonna ping Jakob from WaterCool...WaterCool said:We recommend using demineralised or deionised water (distilled water) as cooling medium. To prevent the build-up of algae, use common citric acid, which reliably prevents the spread of algae.
I grabbed some powder citric acid from the canning section in the grocery store and used that when I flushed out the system!?
demineralised/deionised - Same Thing?
Still wondering if anyone uses a pre-treatment? Either commercial or DIY???
Salud!
