First off i Really want to Thank You in advance for helping.
So i know quite a bit about PCs and overclocking but i never overclocked before and because my CPU is really quite old and i got a GTX 760 i decided i need some more CPU power but i dont have money to upgrade anything at the moment.
So what i did is i pushed my Quad @ 2.5GHz to 3.0GHz (( CPU is NOT unlocked ))
So i changed the "CPU Host Frequency" from 333x7.5 ( 2.5GHz ) to 400x7.5 ( 3GHz )
Mainly screen freezes and (Windows crashes sometimes) started occuring as far as i know there's 2 ways to avoid them 1. Lower frequency 2. Increase voltage so i increased voltage from 1.23V to 1.25V but it kept crashing ( every 5 - 10 min ) so i didnt really want to push it above 1.27V and it still kept crashing so i reverted it back to 1.25V ( i assume it's enough )
I tought it was a Timing issue or something to do with the ram so i changed this setting under "DRAM Performance Control" setting is called "Performance Enhance" changed it from "Turbo -> Extreme" because in the info it said it could improve stability and that changed the crashing to occur every 15-20 min but it's really random mainly occurs if i try to watch a Youtube video that's where it mainly happens or when i use some sites.
If i run a test from OCCT for like 10 min it works just fine no problem and it's not overheating at 100% CPU runs not more than 64 C
But that one time it froze i waited like 20 sec(because i could still hear my friend over skype and when it unfroze cpu was at 100% after like 2-3 sec it dropped back to 2-3%.
I am assuming it's something to do with either RAM timing or RAM speed i really don't know so if you could help i would REALLY appreciate it.
DETAILED SPECS
CPU - Processor: Intel Core 2 Quad - Q8300 @ 2.5GHz (Overclocked @ 3.0GHz )
GPU - Graphics Card: Nvidia - GeForce GTX 760 Windforce Edition 2048MB GDDR5
RAM - Memory: 2 x 2GB Kingston DDR2 Memory + 1 x 2GB A-Data DDR2 Memory + 1 x 1GB A-Data DDR2 = 7 GB DDR2 Memory Total
PSU - Power Supply: High Power - Element Bronze II - 600W
MOBO - Motherboard: Gigabyte EP45-DS3LR 1333+ Dual BIOS
HDD: Hitachi DeskStar 500GB 7200 RPM
OS: Windows 8.1 Enterprise N
CASE: Tacticle Cupboard Case - Yes my PC is indeed in a cupboard. ( Judge me! )
DETAILED SPECS
